In all skins i am missing the star behind the bpm number. Is there a way to get this visisble.
The reason for it is that you will know how the automix will behave, e.g. quick fading from one desk to the other when one of the songs has no star. And nice smooth mix where i only have to kill the bass on the active desk, if both have desks have a star after the bpm number.
geposted Sun 26 Jun 05 @ 5:50 pm
the star is there for all bpm's that VDJ have found consistent for the whole song.
Not all songs will have such a star
If you can't see it in a skin, it might be because the column is to narrow. You can broaden the column at the top, so that it shows the stars as well
hope that solves your problem
geposted Sun 26 Jun 05 @ 10:25 pm
I did not explain correct. The star is visible in the browser area. But once the song is loased on the desk it's gone out of the list and therefor it would be nice to see the star also in the desk area where the BPM is shown
geposted Sun 26 Jun 05 @ 10:48 pm
You should post this in the new features forum. This is built in the skin engine. I don't think there is any variable to show the "*".
geposted Mon 27 Jun 05 @ 12:10 am
