Forum: Greek Forum
Topic: - Drop Outs Help - - Page: 10
apopsisdjPRO InfinitySenior staffMember since 2003
geposted Sun 28 Nov 10 @ 6:53 am
yiannis64 wrote :
Tora pou to les ayto gia to tempro , emena os dia mageias , mou exei exafanistei , otan apo vista ekana anavathmisi se 7 , se prosfora pou mou esteile i idia i Toshiba.
Den exo pleon tempro.
Mallon stin anavathmisi to aperipse , giati thimamai mou eixe aporipsei 2 , 3 pragmata.
Alla an den kano lathos kati paremferi mporeis na kaneis apo to site tis Toshiba an den yparxei to tempro?
H na katevaseis to tempro?
Ta leo ayta kai san apories gia mena , alla nomizo kai i mpety 7 exei an den kano lathos.
Kai telika mipos sta 7 den tempro?
emena eixe k to evgala(twra to evala xana na dokimasw mpas k vrei kanenan driver...)
geposted Sun 28 Nov 10 @ 9:09 am
Loipon katarxin den to ebgala ego to tempro alla mallon mono tou to aperipse i anavathmisi apo vista se 7.
Kai mou ekane ki emena kali douleia sta vista , mexri kai bios eixe anavathmisei.
Tespa epi tou parontos , otan to katevazo apo to site pou mou postares , eno to katevazei , meta leei , to stoixeio tempro installer k.l.p stamatise na leitourgei kai ta windows psaxnoun gia lisi sto provlima k.l.p k.l.p. kai papala.
geposted Mon 29 Nov 10 @ 4:59 am
-Fantazomai katebases tin sosti version gia win7..
-Blepeis to ena problima fernei to allo, stin periptosi sou den ypirxe problima ara ...
-"if it isn’t broken, don’t fix it ..."
geposted Mon 29 Nov 10 @ 5:33 am
Nai fysika tin sosti katevasa , gia ta 7aria , apla den tin kanei install.
Mipos na katevaso gia ta vista , epeidi einai anavathimisi ta 7aria apo vista?
Alla tha mou peis pali , outos H allos to eixa sta vista to programma , kai stin anavathimisi se 7aria , xathike.
geposted Mon 29 Nov 10 @ 6:05 am
erwthsh pros opoion gnwrizei...mesa sto bios exei tin epilogh sata controller mode k einai sto AHCI an tin allaxw tha anoigei o ypologistis???ennow xwris na kanw format na mpw sto bios k na allaxw tin rithmisi mias k einai to mono pou den exw kanei akoma...
geposted Mon 29 Nov 10 @ 8:14 am
PANOSVPRO InfinityMember since 2007
αυτο το mode ειναι για να χρησιμοποιει τον sata driver είτε να τον δουλευει σε ide compatibility mode.
λογικά θα πάρει κανονικά μπροστά
geposted Mon 29 Nov 10 @ 9:01 am
geposted Mon 29 Nov 10 @ 9:19 am
oi diafores poies einai?ennow na doulevei san ide?an den einai oute auto k prepei na gyrisw pali tha milame gia format?
geposted Mon 29 Nov 10 @ 9:26 am
η ταχυτητα ειναι η διαφορα στο read/write του δισκου
geposted Mon 29 Nov 10 @ 1:13 pm
ok to gnwriza auto eipa mhpws htan k kati allo!thanks gia tin voitheia
geposted Mon 29 Nov 10 @ 1:57 pm
to laptop exei paei stin toshiba..mesa stis prwtes wres me phran na mou poun oti den exei tpt(oti pistevame oloi!!!)vevaia tous eipa xana ti provlhma exei k na trexoun to dpc latency pou exw mesa..k exw aporia an tha mou vroun lysh!
geposted Wed 01 Dec 10 @ 9:07 am
δεν υπαρχει περιπτωση κατα 98% να βρουνε λυση γιατι κατα αυτους το μηχανημα δουλευει κανονικα..το ποιο πιθανο ειναι να τρεξουν το dpc checker σε ενα ιδιο η ενα παρομοιο μηχανημα εκει και να σου πουν οτι το κανει και στα αλλα οποτε με απλα ελληνικα δεν κανει το μηχανημα αυτο για την δουλεια που το πηρες...ειπαμε το audio latency ειναι πολυ ψιλα γραμματα για τις αντιπροωπειες μηχανηματων!@
εξαλου δεν αγορασεςι μηχανημα αμιγως dj ενα κοινο λαπτοπ πηρες οπως ολοι μας για γενικη χρηση...το αν θα σου βγει σωστο..ειναι καθαρα θεμα τυχης,αλλιως σου λεει εμεσως..παρε μακ!
geposted Thu 02 Dec 10 @ 1:40 am
Θα διαφωνήσω (για πολλούς λόγους) οτι τα MAC είναι καλύτερα για χρήση Dj αλλά δεν είναι επι του παρόντος.
Το θέμα είναι οτι κάτι φταίει και οτι οι εταιρείες δεν δίνουν βάση και απλά δεν νοιάζονται να βρουν το πρόβλημα.
Να σας πω ένα πρόσφατο πρόβλημα:
Στο γραφείο έχω ένα σταθερό υπολογιστή στον οποίο έτρεχα τον τελευταίο χρόνο Windows 7 Ultimate χωρίς κανένα πρόβλημα. Ήταν ταχύτατος, με μηδενικό audio latency κτλπ.
Για κάποιους λόγους την Δευτέρα χρειάστηκε να κάνω format. Έκανα εγκατάσταση τα Windows 7 απο το ίδιο DVD που είχα κάνει και την πρώτη φορά και στο ίδιο μηχάνημα (χωρίς καμία αλλαγή hardware) το πρόβλημα στο audio latency είναι τραγικό. Για να καταλάβετε το μέγεθος του προβλήματος οποιαδήποτε σύνδεση ή αποσύνδεση συσκευής USB στο σύστημα προκαλεί stutter ακόμα και στον Windows Media Player με WDM drivers!!!
Το καλό σ' αυτή την περίπτωση είναι οτι ξέρω οτι το μηχάνημα πριν το format λειτουργούσε άψογα. Άρα κάτι φταίει... Και ευτυχώς ξέρω και τι μπορεί να φταίει! Πέρυσι όταν έβαλα τα 7 η Gigabyte δεν είχε βγάλει καθόλου drivers για την μητρική μου πέρα απο audio drivers, και όλες οι επιμέρους συσκευές λειτουργούσαν με τους γενικούς drivers των Windows.
Φέτος έχει βγάλει drivers για τα πάντα και τους εγκατέστησα όλους!!! Άρα πολύ απλά κάποιος από όλους αυτούς τους drivers (παρόλο που είναι οι τελευταίοι και πλέον ενημερωμένοι) προκαλεί έντονο πρόβλημα στο σύστημα! Και ήδη υποψιάζομαι τους drivers του chipset της intel καθώς είναι υπεύθυνο για τις USB θύρες.
geposted Thu 02 Dec 10 @ 3:48 am
PhantomDeejay wrote :
Για κάποιους λόγους την Δευτέρα χρειάστηκε να κάνω format. Έκανα εγκατάσταση τα Windows 7 απο το ίδιο DVD που είχα κάνει και την πρώτη φορά και στο ίδιο μηχάνημα (χωρίς καμία αλλαγή hardware) το πρόβλημα στο audio latency είναι τραγικό. Για να καταλάβετε το μέγεθος του προβλήματος οποιαδήποτε σύνδεση ή αποσύνδεση συσκευής USB στο σύστημα προκαλεί stutter ακόμα και στον Windows Media Player με WDM drivers!!!.
Γιαυτον ακριβως το λογο ειναι καλυτερα τα mac. Ολες οι εταιρίες βγαζουν σοφτ για μακ τα οποια δουλευουν στανταρ. Γιατι οι εταιρίες τα ιδια μακ τρεχουν. Δεν εχει 1500 διαφορετικους συνδιασμους. Αν δουλεψει σε ενα μακ θα δουλεψει και στο αλλο. Αυτο ειναι κανονας.
geposted Thu 02 Dec 10 @ 7:11 am
pantws i toshiba den me phre xana apo tote pou tous eipa na trexoun to dpc latency k den symfwnw oti tha mou poun oti den kanei gia tin douleia pou to phra giati poly apla den grafoun oti den einai gia tetoia douleia..twra na to poulhsw ligo dyskolo pou tha vrw antrwpo na poulhsw 40merwn laptop k ante na katalavei giati to dinw tha nomizei oti einai elattwmatiko allwste meta anagastika tha eprepe na paw se mac meta apo olh auth tin talaipwria pou travhxa me to latency pou eixa posa laptop k ematha prin ena mhna ti shmainei audio latency sta laptop...
geposted Thu 02 Dec 10 @ 3:16 pm
loipon paidia milhsa me toshiba opws eipame lene den exei tpt k de exoun lysh sto provlhma k exei arxisei enas agwnas na vrw to dikio mou
an den kataferw na to allaxw den diorthwnetai auto?den yparxei provlhma hardware!sos guys o xronos trexei k lysh akoma den!!!
geposted Tue 07 Dec 10 @ 6:21 am
Egw tha dokimaza kati allo. Vale enan ekswteriko disko, egkatestise ekei to VirtualDJ kai perase oli ti mousiki ekei. Na min xrisimopoiei dld katholou ton C. Apo oti eida eixes trela noumera sto Latency Checker otan ekanes douleies diskou. Min ksexans oti oso trexei to VirtualDJ o diskos kanei diafores douleies (allazei tin database, to history klp)
geposted Tue 07 Dec 10 @ 7:46 am
nai alla to latency to exei k apo mono tou to laptop les an dokimasw auto na alalxei kati?pantws o sklhros den exei thema oute kapoio allo hardware to laptop petaei mono mousikh den mporw na paixw...mporw na kanw egatastash se sklhro xwris windows???
geposted Tue 07 Dec 10 @ 8:07 am
Mporeis na kaneis egkatastasi to programma se allon disko alla gia mena -eimai sigouros 100%- pws den tha allaksei apolytos tipota me ayto.
To mono pou den ekanes kai ego tha eskaga an eimoun sti thesi sou kai den to dokimaza, einai na baleis to sata se Ide /compability mode apo to bios (h erotisi pou ekanes) kai na baleis xp.
Ksero se bazo se mpelades, alla..
Epeisis tha epemena akoma ligo na apenergopoihso tin karta grafikwn pou babaia einai mono ena check kai oxi lysi.
Alla ta windows xp ... an sou katsoun einai lysi. Kaneis kai ena dual boot meta..
geposted Tue 07 Dec 10 @ 8:33 am
90%
