I had save about 15 playlist in VDJ
I want to remove some that are old The software says "do you want to remove the playlist"
Now does this mean remove it from my computer or just from its folder. The first I press yes to be remove and my playlist was sent to the recycle bin. I Instantly restored my playlist think It deleted the playlist and the files from there original folders. Can someone tell that it removes them from the playlist folder or deletes them permanently.
I have version 3.0
Thanks
I have version 3.0
Thanks
geposted Mon 27 Jun 05 @ 6:33 am
By deleting a playlist you don't delete your tracks; only their shortcuts written in the playlist file (.m3u).
geposted Mon 27 Jun 05 @ 9:48 am
Thank you
geposted Wed 29 Jun 05 @ 6:31 am
