Topic: hercules console
I was just wondering if you plug your hercules console into your laptop does that give you the headphone cueing and master sound output so it acts as an external sound card.
thnx again
geposted Mon 27 Jun 05 @ 9:44 am
Yes it does.
Please if you own a console make itrecognize here by updating your profile: https://virtualdj.com/fusers/modifuser.html
... be carefull that the software included with the console is not the full version.
Here is a link for the console (in french) with pictures of its connectors.
Regards,
Clax
The software that is included with hercules console is it the full version edition of virtual dj
Its a bit of a difference...
The free program that comes with the console is fully working (no time limits like demo), but its a dedicated console version that works with the console only.
It has a couple of limitations such as not being able to connect to external mixer, and its NOT the same as the full profesional version of VDJ
The console version is at version 1.09, while the pro version is at version 3.0
The pro version gives a couple of great features that the console version does NOT have :
- Ability to connect to external mixer (2x stereo out from console)
- Ability for basic scratch with console jogwheels
- A bunch of new features added (such as sampler engine, better sound engine, video mixing etc etc)
- ability to download amazing effects
For a comparison look here :
https://virtualdj.com/products/comparison.html
If I buy the console with the bundles of software and then buy the full virtual dj program after,will the console work with the full version insted of the console one
yes... the console works with the full pro version of VDJ,... it works even better, as a features such as scratch (jogwheels) and the ability to invert features etc are added to the console functionality with the full pro version of VDJ
