Forum: Old versions
Topic: Installation error
Just downloaded the program and when i click install is reads
Could not initialize installation. File size expected= 2999540, size returned=8004604. the parameter is incorrect...
need help...dont know what wrong.
geposted Mon 08 Nov 10 @ 7:38 pm
If you get an error message above the size of the installation file, then this means that it has not downloaded in full.
Please download it again: https://virtualdj.com/download/free.html
If the problem persists, make sure that you any download managers are disabled (These commonly cause problems with downloading the installation file.) Try using a different web browser to download (If you normal use Internet Explorer, try using Firefox, or vice-versa.)
Also, make sure that your anti-virus signatures are fully up-to-date and perform a full scan of your system to ensure that it is virus free (It could be a virus infecting and interfering with the installation file.)
were u able to dl and install it properly?
