I am not using my Echo Indigo DJ sound card, Should I sell it? anyone want it before I list it on ebay?
Echo Indigo DJ sound card - Dual stereo output 4 Channels works with VirtualDJ
http://www.pcaudiolabs.com/images/products/indigo_large.jpg
http://www.turntablelab.com/eq/pics/echo-indigo.jpg
ideal portable solution for the digital DJ. Indigo DJ offers two independent stereo 1/8 inch analog outputs; one for setting up your cue mix on a pair of headphones, and the other for the house mix. Each output features 24-bit/96kHz converters for the quality you deserve. Also included is a 6 foot audio cable for RCA or 1/4 inch connections.
unique feature of the Indigo DJ is the use of "virtual" outputs. Indigo DJ appears to software as if it has eight separate outputs, which are digitally mixed down to the physical outputs using Indigo DJ's "console" software and its on-board DSP. This makes Indigo DJ compatible with all popular multi-track software. And, with Echo's "multi-client" drivers, more than one application (such as an editor and a software synth) can be playing back through Indigo DJ at the same time.
Features...
* 2 independent stereo 1/8" analog outputs
* Preview cue mix on the headphone output while playing back house mix on the line output
* High quality headphone amp
* Analog volume control knob for headphone output
* Supports true 24 bit, 96 kHz audio
* High quality digital to analog converters
* 100 MHz 24 bit Motorola DSP
* Powered by your notebook computer
* Includes 6 foot adapter cable for RCA and 1/4" connections
* Type II Cardbus slot required
* Software console for metering and setting levels
* Supports Windows Me/2000/XP and Macintosh OS X (Jaguar & Panther)
* Supports pro audio and DJ software (WDM Kernel Streaming, ASIO, GSIF, and CoreAudio)
* 8 "Virtual Outputs" - run multiple applications at the same time
* Low-latency drivers
Features...
geposted Mon 27 Jun 05 @ 7:43 pm
asking price??? and i assume this was tested with TCV?
geposted Mon 27 Jun 05 @ 7:57 pm
TCV needs 4 lines IN, this has 4 lines out. Thinking like $99
geposted Mon 27 Jun 05 @ 8:03 pm
i was thinking as a second soundcard, but that not much less then a maya so i think i'll pass
geposted Mon 27 Jun 05 @ 8:08 pm
Maya is GREAT. 4 line ins, 4 lines out. only thing I do not like is that it is another EXTERNAL device hanging out. The Echo sits inside the laptop and you can barely tell it is there.
geposted Mon 27 Jun 05 @ 8:36 pm
ha ha i have so much junk hangin' out thats the least of my worries
geposted Mon 27 Jun 05 @ 8:46 pm
