how do i move my sofware from one computer to another including the catalog. i just brought a new computer just for virtual dj and i want to get it off my main computer.
geposted Tue 28 Jun 05 @ 1:33 am
For the program, you need to copy your vdjinstall.exe to a disc and then load from there onto the new machine...while it's connected to the net.
for the music itself, if you have an external hdd, just plug it into your new computer and hey presto...if not, you can either swap hdd's around or link the two pc's together and copy your music over that way.
personally i swap hdd's over. make sure the hdd you are putting into the new machine is virus free...if not it'll only cause you problems in the long run - i'm having a few myself right now...grrrr...
if you have copied everything over, you should be ok to go.
good luck - let us know how you get on.
Keep spinnin'...:o)
P
Keep spinnin'...:o)
P
geposted Tue 28 Jun 05 @ 1:39 am
Don't forget to copy your parameters:
shortcuts.xml
VirtualDJdatabase.xml
(not "mp3database.txt" -> do a new scan (not extended))
shortcuts.xml
geposted Tue 28 Jun 05 @ 9:15 am
