Someone has successfully upgrade Virtual DJ for version 7.0.1?
geposted Wed 17 Nov 10 @ 6:45 pm
I have the upgrade works great like always :)
geposted Wed 17 Nov 10 @ 8:39 pm
Have you checked if it actually updated to version 7.0.1? Mine was installed but still in version 7.0.
geposted Thu 18 Nov 10 @ 4:48 am
After installing upgrade go to your applications, that's where the new thing is. change out icons in your dock and voila!!!
Happy mixing.
Happy mixing.
geposted Thu 18 Nov 10 @ 5:39 am
Thanks man, I had not seen this detail.
geposted Thu 18 Nov 10 @ 8:40 am
is there a change log?
geposted Thu 18 Nov 10 @ 9:07 am
Here is the change log from the Wiki, found here: http://www.virtualdj.com/wiki/VirtualDJv7.0.1.html
fixed left/right for dual-deck controllers on multidecks skins
fix on mac for MIDI controllers with several virtual "ports" (xponent, uc33e, ...)
fixed 4-deck controllers in 2-deck skins
fixed mismatched dual MIDI controllers if VID/PID reported in wrong orders by windows
new registry hack: DisableBuiltinDevices, ScanMIDInoPID
fixed crash if apply-to-all in fileinfo included the separator
fixed VDJScript "page 'effect' ? effect activate" (and other similar scripts) keeps the skin button lit
new VDJScript action "param_cast"
new VDJScript action "get time [elapsed|remain|total|loopin|loopout|cueX] [absolute] [{resolution}]"
new VDJSCript action "deck X get controller_name"
fixed MIDI LED <bar cc="" full="true"> first led was always lit
new MIDI xml <text sysex="" offset="" size=""> will "insert" the text at offset if offset+size>sizeof(sysex)
MIDI xml <text> can use encoding="ascii" to ensure 7-bit midi compatibility.
fixed <text sysex=""> with insert
new controllers DJ2GO, GEMINI16.
modified controllers FFKTLR, MC6000, SC2000, SPIN, DJCMK2, DJCMK4, DJCRMX, VCI300
I just updated, and it appears to be working great so far.
EDIT: Its working fine after swapping out the icon as mentioned a few posts up.
geposted Thu 18 Nov 10 @ 1:42 pm
yo nesito conectar este versión por compre es 7.0.1 numero de serie es [NOT A GOOD IDEA TO POST YOUR SERIAL NUMBER]
geposted Sat 04 Apr 20 @ 2:07 pm
