Anyone here know how to access the config menu via the keyboard?
Seems I have a bad habit of trying out new skins who's config buttons are incompatible with never versions of VDJ, and consequently can't access the menu to change them once I've committed...
geposted Sat 20 Nov 10 @ 1:16 pm
          It is possible...
Just create a keyboard shortcut.
The action is 'settings'
I use control+shift+return... for this.
geposted Sat 20 Nov 10 @ 5:44 pm
          Alright, thanks Apopsis.  That won't get me out of my current jam.  But at least I'll be ready next time, once I've set it up.  You'd think they'd include a shortcut for that function by default, but, oh well...  I suppose it is what it is...
    geposted Sat 20 Nov 10 @ 9:13 pm
          Re-install VirtualDJ and it will revert back to the default skin.
Or delete the appropriate custom skin that you installed from My Documents\VirtualDJ\Skins
geposted Sun 21 Nov 10 @ 5:58 pm
          Yeah, (reinstall) that was the route I decided on.  This isn't the first time I've encountered this problem, so I knew that would work if it became necessary.  I found that I couldn't use Apopsis' specific key combination though, as it happens to be the the default for the track preview function, at least with my V7s.
Now,.. if only the software *was actually* fully integrated with the Numarks, this would be a killer combination. But alas, I guess for now I'll have to go back to using Seroto.
geposted Sun 21 Nov 10 @ 8:39 pm
          i chose the wrong skin and the config button was off screen.
i exited the app using Alt+F4. When VDJ reloads it tells you the skin is the wrong size for your resolution. Press Cancel. The default skin should now be in use so you can go to Config and change what you need.
Press ALT+F4 to exit the app
Load the App again. Press Cancel
Default Skin is now shown
Hope that helps someone...
Regards.
Regards.
geposted Tue 20 Dec 11 @ 6:55 pm
          thank you profess!!!!!!!!!
    geposted Fri 30 Dec 11 @ 8:35 am
          Hi guys
same prob with Red ClubDJ Pro skin
noting here seem to work any more ideas
geposted Wed 11 Jan 12 @ 9:13 am
          hi,
i tried to map my keyboard with virtual dj pro7,its gettin mapped but its not gettin saved.pls give me a solution..
geposted Mon 15 Oct 12 @ 1:36 pm
          Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center:  http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it.)
Once you have done this, please see our FAQ pages: http://www.virtualdj.com/wiki/VirtualDJ%20Folder%20Permissions.html
geposted Tue 16 Oct 12 @ 7:54 am
          shift + Esc will get you in to config that will do it my friends don't delete any thing unless you need to.
    geposted Wed 02 Dec 15 @ 4:52 pm
          can someone help me here my config button is not working after downloading virtual dj le
    geposted Thu 29 Sep 16 @ 12:25 pm
          What do you mean by 'not working'?
VirtualDJ LE 7 (and earlier) have very restricted config options.
geposted Thu 29 Sep 16 @ 5:22 pm
          when i open the config button it only tell me to upgrade to pro version
    geposted Sat 01 Oct 16 @ 2:28 pm
          This is a dumb question but I'm trying to find where the configure button /Internet is in the first place..
    geposted Mon 17 Oct 16 @ 3:56 am
          key bord vertual dj
    geposted Sat 29 Sep 18 @ 8:37 am
          How can I set my talking drums to respond quickly
    geposted Sat 20 Mar 21 @ 5:59 am
Those are in sampler, and by default are triggered on keyboard with F1-F12
How they trigger/playback you can select in sampler area (stutter, hold, etc)
Look at trigger mode here:
https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
geposted Sat 20 Mar 21 @ 11:12 am
