What are the differences between the different crossfader settings? (Scratch, Smooth, Full... not sure of the other ones).
geposted Sat 20 Nov 10 @ 8:18 pm
This diagram will help you to understand the difference.
Note. These red & blue lines (deck 1 & deck 2 ) actually add theire volume to the output. So in other words, in full crossfader you will have larger volume output in the middle (crossfader 50%)
[EDIT] Picture edited.. i hope this time is correct ..
geposted Sat 20 Nov 10 @ 8:37 pm
Scratch picture is wrong. The picture is more the "CUT" transition
geposted Sun 21 Nov 10 @ 12:18 pm
i know this is old but where do you find this setting in VDJ8?
edit: found it
edit: found it
geposted Mon 25 May 15 @ 12:56 pm
Where is it
geposted Sun 13 Mar 16 @ 2:08 pm
Perhaps if you read the manual....?
geposted Sun 13 Mar 16 @ 3:04 pm
hi, although the crossfader appears to show its working on my screen, it isn't actually doing anything at all. and when I load a deck, the other deck stops dead in its tracks. so im having to work using play list.
geposted Tue 15 Mar 16 @ 6:12 pm
