Hi *,
am I able to see the BPM of the files in the playlist.
Maybe one of this hairy Regestry keys?
THX Mathew
THX Mathew
geposted Fri 22 Aug 03 @ 9:09 am
Mathew:
"am I able to see the BPM of the files in the playlist"
Yes you are.
All others columns are in the playlist (BPM,LENGTH,COMMENTS)
You just have to reduce the AUTHOR column (by the right) and the others one will appear (one by one)
Yes you are.
geposted Fri 22 Aug 03 @ 9:17 am
