Is it possible to change what the get food option does? Could it be changed so that it brings a different application to the front of VDJ? (not open).
I am asking this as I use a broadband dongle to connect to groove shark. I have found that my broadband dongle application also receives text messages as well.
I am now using this feature as a free way to get txt to screen, by minimising VDJ and copying the txt from the broadband application.
What I would like to do if possible is use the get food option to bring this application in front of VDJ, instead of minimising VDJ every time
(Don’t like minimising VDJ).
Thanks for any help, Ian.
geposted Wed 24 Nov 10 @ 3:41 am
There isn't at present I'm afraid. You could always Alt+Tab instead of minimising though.
geposted Wed 24 Nov 10 @ 5:49 am
Thanks for the reply scott. Alt Tab it is then for now.
geposted Wed 24 Nov 10 @ 6:16 am
You could also use the windows key to expose the task bar and click on what you need....
geposted Wed 24 Nov 10 @ 11:47 am
Thanks for the info
geposted Fri 26 Nov 10 @ 6:03 am
