Hi,
I am A HDJC user (at work so thats why it doesnt appear on my profile) And I am contemplating moving over to the full retail version (V3). But before I do, please can you tell me if the software will allow me to hear both decks on my headset? I could not find the answer in the forum.
What I am trying to determine, is whether I can Hear both tracks (with variable levels) in my head set, then move over to the Live out put. As one would with a PGM/Cue switch on a mixer?
geposted Thu 30 Jun 05 @ 10:19 am
Yes, it is possible to hear both decks mixed together as well as the two individual decks.
Hoping to see you soon as a full registered version.
regards,
aditya
regards,
aditya
geposted Thu 30 Jun 05 @ 12:16 pm
Don't forget to make your console recognized here by updating your profile.
(https://virtualdj.com/fusers/modifuser.html)
geposted Thu 30 Jun 05 @ 1:02 pm
"some" skins have a "headphone_mix" slider that allows you to determinate which volume your second deck is hearable in the headphones.
Push the slider to the max and deck 1 & 2 will be hearable at the same volume in headphones.
Try the Pioneer CDJ 700-S it has this slider on it (but not all skins).
FRUiT94
FRUiT94
geposted Thu 30 Jun 05 @ 1:31 pm
Wow, thanks for the response guys.
Really appreciate it.
geposted Thu 30 Jun 05 @ 3:22 pm
I bought the Hercukes deck and can not hear both decks in cue. what do I need to do to be able to hear them at the same time? Also my deck always reset pitch to -0- even when I disable the feature and anyone tell me why?
geposted Sun 03 Jul 05 @ 4:52 am
