i have the hercules mk2 mixer and want to know how i cam convert my videos from itunes for the vdj software and hercules mixer to be able to mix them, any help would be much appreciated.
geposted Fri 26 Nov 10 @ 11:46 pm
I get videos from itunes all the time and don't need to convert them............Exactly what happens when you try to play a video??
Huey
Huey
geposted Sat 27 Nov 10 @ 2:18 am
Sorry, it is not possible to play these videos in VirtualDJ v5 limited DJ Console Edition because these files use a newer encoding method that is not supported by this older version of the software.
To play these videos, you will either need to upgrade to the latest VirtualDJ Pro v7.0.1 https://virtualdj.com/buy/ or convert the videos to another supported format for v5, e.g: MPEG2
geposted Sat 27 Nov 10 @ 2:06 pm
I have virtual dj pro 7.0.2 when I go to click on my itunes videos folder in vdj there's nothing there why this just happened when I updated to vdj pro 7.0.2 the videos are in itunes but don't show up when I run vdj can you help me with this.
geposted Thu 23 Dec 10 @ 8:03 am
If they were purchased in the iTunes DRM (Digital Rigts Management) days, they would say "Protected MPEG-4" Show below:
There is no way to play or convert these videos for use in anything other than iTunes (fault Apple and the RIAA for that).
BUT there may be hope! iTunes often allows you to purchase an upgrade to the DRM free version of your previously purchased "protected" videos. Go to the iTunes store and on the right under quick links, look for and select "upgrades" (I think). It is about $.60 a video and the DRM free, iTunes + files play in VDJ just fine with no conversion needed. I have well over 200 of them and mix with them at clubs all the time. Good luck!
geposted Thu 23 Dec 10 @ 9:17 am
There's no DRM on them what so ever I checked..
geposted Thu 23 Dec 10 @ 9:22 am
Is video enabled? I had it disabled for a while when I had a slower computer and it did not even see the videos.
geposted Thu 23 Dec 10 @ 5:07 pm
Video is enabled I did A Complete uninstall and still the same do you have any idea why this happened
geposted Thu 23 Dec 10 @ 7:49 pm
Not really man, I need more details, screen shots, anything more than "I go to the video folder and don't see anything". I am out of guesses.
geposted Sat 25 Dec 10 @ 7:48 pm
