Hey guys,
I have some TCV and decks, now I want a fairly inexpensive lappy to cart around with me. I've decided to get a laptop over a rack mounted system for a number of reasons, so please don't suggest this as an alternative :P
Any idea what I could have for the minimum specs? Dell has some good deals ATM , with 35% off already cheap prices.
I was thinking something like...
Pentium M 1.73
1 gig ram
17" screen
100 gb hard drive
nvidia 6800 128mb
for about $1400/1500
Do you think this would do for (audio only) mixing w/TCV?
cheers everyone.
Pentium M 1.73
1 gig ram
17" screen
100 gb hard drive
nvidia 6800 128mb
cheers everyone.
geposted Fri 01 Jul 05 @ 3:01 am
Check out ACER computers aswell, they are quite cheap.. For audio only, you will manage quite well with less power in CPU and RAM...
I manage excellent with AMD XP-M 2600+, 512 RAM (-64MB for video) 15" display 40GB HD (250GB external drive), so it is always a question in what you want and what you really need...
I, however, don't use TCV's. But is there a big difference?
geposted Fri 01 Jul 05 @ 5:40 pm
thanks antileon, yeah i imagine I won't need a whole heap of power, but I want the laptop to last through the next few versions of vdj as well
geposted Fri 01 Jul 05 @ 8:38 pm
@ninja
You will save some money and get more power for you buck if you avoid Centrinos, Celeron-M's and Pentium-M's. Otherwise, you pay extra for the luxury of extra battery life and speed-step technology, etc. Of course, I am assuming you plan to use the lappy plugged in and the battery is just there in case of power problems, so, like me, 5 minutes of battery is probably more than enough for you? ;)
geposted Fri 01 Jul 05 @ 11:43 pm
frd - good point, size/battery isn't really an issue in this case..
geposted Sat 02 Jul 05 @ 1:45 am
