does vdj support asian languages? i tried to load mp3 files w/ chinese characters and vdj does not load them.
bbj
bbj
geposted Fri 01 Jul 05 @ 8:47 am
geposted Fri 01 Jul 05 @ 9:22 am
I think it should work as Virtual DJ uses Unicode
geposted Sat 02 Jul 05 @ 11:44 am
i am on windows xp and can use chinese in programs however, in vdj the characters are shown as question marks.
bbj
bbj
geposted Sun 03 Jul 05 @ 2:45 am
Virtual DJ does NOT use UNICODE!!!!!!
geposted Tue 20 Sep 05 @ 2:30 pm
@DJRogerBorges
It's written in the features vdj v2.0
"Compatibility with Asian OS (unicode filenames)"
https://virtualdj.com/products/virtualdj/history.html
And when you use DirectX, in general, you program in UNICODE but you may be right
geposted Sat 24 Sep 05 @ 10:31 am
any response from vdj corporate support team?
bbj
bbj
geposted Tue 27 Sep 05 @ 10:11 am
I'm not sure if unicode is supported,
for Greek language i need to modify the skin xml, take a look at this
https://virtualdj.com/forums/41169/Software_Technical_Support/ARABIC_LANUAGE.html?highlight=arabic
geposted Tue 27 Sep 05 @ 3:15 pm
