How about a parameter on VOLUME, that let's you do fades in ms in or out. There is one for CROSSFADE, but not for VOLUME.
Uses: I wanted to add buttons to execute a script on each player on the six player skin to do a seven second fade out, then pause, and return the volume to normal.
If you are DJ'ing only from the software, without controllers, you can use the mouse to do only one thing at a time. Set a button to do a fade for you and you can do something else at the same time.
geposted Wed 01 Dec 10 @ 7:30 pm
