Setup: Intel MBP, VDJ7 Pro, Ableton 7, Hercules Control Steel, AKAI APC40
Rewire is configured OK and shows up on a deck as an Aux In.
Tempo lock is good and sound is fine.
What I can't figure out is how to make VDJ ignore the APC so that I can keep using it with Live.
Can anyone help me out with this?
Big thanks!
T
Big thanks!
T
geposted Thu 02 Dec 10 @ 3:33 pm
<Bump> I still need help on this one...
geposted Mon 06 Dec 10 @ 4:28 pm
bumpity
geposted Mon 13 Dec 10 @ 9:15 pm
Bump
geposted Wed 12 Jan 11 @ 1:00 am
Bumpity. Really can't belive no one has any input on this...
geposted Sat 22 Jan 11 @ 4:56 pm
You can bump as much as you want, but if nobody knows a soultion ................
As far as i know, you can only ignore "all" USB devices, but not only one specific.
But i will ask a friend of mine, maybe he knows more.
geposted Mon 24 Jan 11 @ 7:30 am
Geht mit dem akt. Registry Tool 'Disable Builtin Devices' schaltet alle Definitions ab. D.h. Wenn Du einen Controller in VDJ nutzen willst musst Du Definition und Mapper selber schreiben.
Load the Registry Tool ( https://virtualdj.com/addons/2170/Registry_Tool.html ) and "Enable" 'Disable Builtin Devices'.
So if you now use your RMX, you have to create a own Definition and Mapper File to get only your RMX work.
Have a look in our Download Area, maybe there is both.
https://virtualdj.com/addons/controllers.html?category=best&order=default&search=rmx
If yes, put the Definition File into the folder Device and the Mapper File into the Mapper Folder.
After that, only the RMX should be connected with VDJ.
Hope this was, what you are asking for.
geposted Tue 25 Jan 11 @ 2:09 am
