leonidassr wrote :
sthn ousia epeidh klikaroun, prepei na ta gyrizeis panw apo 360 moires gia na ftasei apo th mia akrh sthn allh. 8a mou peis 8ema mapping einai ayto, alla an to kanw etsi wste na einai o logos (gyrisma software/gyrisma knob) =1, tote 8a xasei se analysh. an pali 8elw poly ypshlh analysh, 8a prepei na gyrizw sxedon 2 fores to knob gia na paei to fx apo th mia akrh sthn allh....
Akou ton papou se auto. Sta fx otidhpote knob douleuei se euros perisotero twn 270 moirwn DEN einai fx knob . Meiwse tis moires isws an to baleis na douleuei ws progressive kai oxi 1:1
Ta endless einai bolika gia na ta syntoniseis se perissotera effects kai mporoun na einai ligoreto epireph se lathi . Omws to feeling th stigmh pou to bazeis den einai to idio kata th gnwmh mou. Kai kurios den mas apasxolei to klick sthn arkh alla sth mesh. An milame bebaia gia katw apo 128bpm den uparxei problhma prolabaineis na diorthwseis aneta kai me endless.
geposted Wed 29 Dec 10 @ 7:23 pm
Hello ksenyxtides..
Peiramatistika aytes tis meres me ta fx tou Pio djm-800 hai me ta filtra tou Texzk mapping sta cdj-900 kai katalabaino ti thelei na pei o 'papous' Dimitris. Omos to idaniko tha htan na exeis 2 encoders, ena me 270 kai ena endless, kai sto vdj toulaxiston mporei na ginei ayto me exypno mapping kai oikonomia sta koumpia.
O Djm-800 exei kapoia ammesa fx (4) pou ta energopoieis apeytheias me 4 buttons kai exeis apo ena encoder se kathe kanali tou mikti pou einai min-max peripou 270 moires, sti mesi exei klik kai kanei reset/bypass. Ayta boleyoun poly gia grigoro peiragma.
H basiki monada fx omos exei ena endless me poly megali analysi. Se kamia periptosi den prolabaineis na ftaseis sto simeio pou to theleis kai na eisai in sync, omos kapoia rolls kai ena aytomato filtro pou exei akougontai oraia me tin megali analysi, nomizo an eixa kai ena min-max encoder dipla pou na kanei tin idia douleia gia na sbineis grigora ta fx anti gia on/off tha htan teleio. Paromoia test ekana kai me to mapping sta cdj900 px, mapparontas to filtro sto megalo jog dinei terastia analysi, tha dokimaso na kano ayto me to diplo mapparisma.
geposted Wed 29 Dec 10 @ 7:49 pm
djdad wrote :
Ena koumpi to vazeis na kanei cycle mia var
cycle 'brows' 4
Auto pairnei kyklika tis times 0,1,2,3,
kai meta vazeis ena allo koumpi na kanei to sort.
var_equal 'brows' 1 ? browser_sort 'bpm' : var_equal 'brows' 2 ? browser_sort author' : var_equal 'brows' 3 ? browser_sort 'title' : browser_sort
To teleutaio kanei to smart sort. Episis mporeis na auksiseis to cycle se megalytero arithmo kai na prostheseis ki alla sortings.
cycle 'brows' 4
Mpampi, ayto douleyei alla prepei na baleis " " anti gia ' ', allios bgazei syntax error. Pote den katalaba pote mpainei to ena kai pote to allo..
geposted Wed 29 Dec 10 @ 7:56 pm
dhmhtrh dn ginetai n meiw8ei allo. gt meta xanei se analysh opws s eipa, k akougetai polu entona h metavolh ap th mia 8esh sthn allh. g ayto lew n xtyphsw k ena X1, mono gia fx twra... :P
geposted Thu 30 Dec 10 @ 6:55 am
Καλησπέρα!
Λοιπόν οι πρώτες εντυπώσεις απο το controller είναι πάρα πολύ καλές.
Θα ξεκινήσω εδώ ένα mini review και άυριο λογικά θα κάνω ένα κανονικό review μαζί με φωτογραφίες και άλλο υλικό σε ξεχωριστό νήμα.
Πρώτα θα αναλύσω το κομμάτι του μίκτη.
Αναπόφεκτα η άμεση σύγκριση αφορά τον DENON και ένα VESTAX VMC-004 με τον οποίο έχει στηθεί ο ήχος στο μαγαζί.
Ο DENON αποδείχθηκε λίγο πιο "μπασάτος" σε σχέση με τον Vestax. Χαμηλώνοντας τα μπάσα κάτα ένα περίπου db απο το driverack ο ήχος είρθε στα "σωστά" του, αλλά και πάλι ο DENON έβγαζε πιο "γεμάτο" και "ζεστό" μπάσο πράγμα που εμένα προσωπικά μου άρεσε.
Ξεπερνώντας το θέμα της χροιάς ο DENON απο γκάζια έχει μπόλικα. Ακόμα και για κάποιον παρανοϊκό με την παραμόρφωση σαν κι εμένα κατάφερα να φτάσω το ηχοσύστημα άνετα στα όρια του κι ο DENON είχε να δώσει κι άλλο. Σε σχέση με τον Vestax πρέπει να είναι λίγο πιο ύσηχος όμως. Ενδεικτικά το Limiter του Driverack είχε ρυθμιστεί να χτυπάει στα 0 db out του Vestax. Με τον DENON χρειάστηκε να φτάσει τα +3db για να χτυπήσει το limiter αλλά όπως είπα και πριν υπήρχε ακόμα πολύ περιθώριο για "γκάζια" (το Master ήταν κάπου μεταξύ 2 και 3 η ώρα και τα Upfaders στο 70-80%)
To EQ του DENON είναι ένα τυπικό 3-band EQ. Η απόκριση είναι πολύ καλή όπως και ο διαχωρισμός των συχνοτήτων. Το EQ έχει την τάσει να "συγχωρεί" για ρυθμίσεις απο 0 μέχρι +2+3db. Έχει δηλαδή μια μικρή "ελαστικότητα" στην αρχή των θετικών ρυθμίσεων πράγμα που για dj's είναι καλό.
Τα UPFADERS είναι σκληρά και απροβλιμάτιστα. Η απόκριση τους είναι γραμμική με ελαφρά αύξηση της γραμμικότητας απο το 90 έως το 100%
Το Crossfader αντίθετα είναι αρκετά μαλακό και με ένα "χτύπημα" μέχρι το 30% μπορεί και να φτάσει στο 70-80% Η καμπύλη του είναι ρυθμιζόμενη οπότε μπορεί να βολέψει όλα τα γούστα. (προσωπικά δεν χρησιμοποιώ crossfader και χθες το χρησιμοποιήσα μόνο για video)
Γενικά το layout του μίκτη είναι αρκετά καλό και παρά το "συνοστισμό" δεν υπάρχει κάτι που να μπλέκεται στα χέρια σου κατα λάθος.
Στο κομμάτι του controller τώρα:
Σαν controller είναι αρκετά καλός. Τα πλήκτρα είναι τυπικά "λαστιχένια" πλήκτρα DENON τα οποία όμως έχουν πολύ μικρή διδρομή και κάνουν ένα ξεκάθαρο κλικ όταν τα πιέζεις. Γενικά για dj's σαν κι εμένα που έχουν την τάση να έχουν το δάχτυλο πάνω στο κουμπί μέχρι την στιγμή που θα το πατήσουν ο DENON έχει καριβώς την σκληρότητα που χρειάζεται. Αρκετή για να μην πατηθεί το πλήκτρο κατά λάθος και λίγη για να πατιέται απρόσκοπτα την κατάλληλη στιγμή.
O MC6000 έχει ως επι το πλήστων απλά encoders καθώς το ΜΟΝΑΔΙΚΟ endless encoder είναι το track selector! Χθες δεν είχα την ευκαιρία να "παίξω" με τα encoders για να δοκιμάσω την απόδοση τους σε effect κτλπ καθώς η βραδιά ήταν Rock party! :p
To pitch slider παρόλο που είναι σαφώς μικρότερο απο αυτό της SC2000 είναι επίσης αρκετά καλό. Έχει μια πολύ καλή σκληρότητα (παρόμοια με αυτή των upfaders) και αρκετά καλή ανάλυση. Κάνει "κλικ" στο κέντρο πράγμα που προσωπικά το θεωρώ απαραίτητο σε pitch slider.
Τα jogs είναι μια "ιστορία" απο μόνα τους. Είναι λίγο μικρότερα απο αυτά ενός CDJ-400 πχ αλλά αρκετά μεγάλα για όλες τις λειτουργίες εκτός απο σοβαρό scratching. Επίσης είναι λίγο σκληρά και δεν βολεύουν για "ελεύθερο" backspin. Αν τα συγκρίνω με τα CDJ-400 έχουν περίπου την ίδια σκληρότητα με τα Pioneer να είναι λίγο πιο σκληρά. Το touch στα DENON γίνεται μέσω τεχνολογίας αφής. Δεν υπάρχει φυσικό πλήκτρο που να πιέζεται για να δώσει ο controller την εντολή touch. Είναι ενδεικτικό οτι άν κάποιος προσπαθήσει να ακουμπήσει απαλά το πλατό με τα μήλα των δαχτύλων του, πριν καν προλάβει να νοιώσει το πλατό με την αφή του ο controller θα έχει στήλει την εντoλή touch. Το πλατό έχει δύο ζώνες, τον εξωτερικό δακτύλιο και τον εσωτερικό κύκλο αφής. Ο εσωτερικός κύκλος αφής απενεργοποιείται και απο το hardware. Η θέση τους είναι αρκετά καλή και αν εξαιρέσουμε τα πλήκτρα CUE/PLAY δεν υπάρχει τίποτα που να μπαίνει στην μέση κατά τον χειρισμό τους.
Το γενικότερο layout είναι αρκετά βολικό και όπως είπα κάπου και παραπάνω παρά το συνοστισμό δεν υπάρχουν πράγματα που να μπερδεύονται μέσα στα χέρια σου την στιγμή που δεν τα θέλεις. Ακόμα και για μένα που έχω πρόβλημα με τον μίκτη στο κέντρο (και χθες για να βγάλω αλλαγή απο το αριστερό deck είχα τα χέρια μου "χιαστή") το layout ξεπέρασε τις προσδοκίες μου.
Το κομμάτι της κάρτας ήχου το άφησα τελευταίο γιατί αυτό είναι κάτι που δεν είχα την ευκαιρία να "ψάξω" ιδιαίτερα και δεν θέλω να το αδικήσω. Γενικά χτες επειδή έστεισα γρήγορα χωρίς να έχω αρκετό χρόνο για δοκιμές αναγκάστικα να χρησιμοποιήσω την κάρτα ήχου της DENON με αρκετά υψηλό latency πράγμα που με απογοίτευσε αρκετά. Παρόλα αυτά επιφυλάσομαι να κάνω περισσότερα test και ρυθμίσεις για να εξάγω τα σωστά συμπεράσματα...
Υ.Γ.:
Σε μια πολύ μικρή δοκιμή που έκανα να δουλέψω τον μίκτη ως MIDI Mixer έμεινα έκπλεικτος απο την αμεσότητα ανταπόκρισης του software. Γενικά η αίσθηση του μίκτη ακόμα και σε MIDI mode ήταν σχεδόν ίδια με αυτή του hardware μίκτη!
Υ.Γ.:
geposted Thu 30 Dec 10 @ 11:08 am
George, thanks gia to analytiko review pou esy onomazeis 'mini'...
To kentro kai h aksia tou pisteyo einai o miktis.
Basika exeis agorasei enan pliri mikti 4ch poiotitas Denon.
geposted Thu 30 Dec 10 @ 6:58 pm
Polu kalo to rewiew kai apo atomo pou h gnwmh tou prepei na lamvanete sovara ypopsin.. Mia erwtish mono giati skeutomai sovara thn agora neou controler.. Ta pich faders den 8ewreis oti einai polu strimogmena kai shmeio opou den voleuei h xrhsh tous? Idika to aristero..
geposted Fri 31 Dec 10 @ 3:31 am
Για τα pitch faders αν και φαίνονται στριμωγμένα εντούτης είναι σε ιδανική θέση πιστεύω. Η λογική της DENON να μην κάνει Mirror τα χειριστήρια είναι πολύ καλή και σωστή. Τα αριστερό Pitch fader είναι το πρώτο "ψηλό" χειριστήριο απο αριστερά προς τα δεξιά (τα hotcues είναι αρκετά πιο χαμηλά σε ύψος) και λόγω και της σκληρότητας τους είναι σχεδόν αδύνατο να κουνηθούν κατά λάθος.
Έχω τραβήξει μερικά βιντεάκια τα οποία θα ανεβάσω αργότερα!!!
geposted Fri 31 Dec 10 @ 7:25 am
peripou poso mhkos exoun ta pitch faders? panw apo 6?
geposted Fri 31 Dec 10 @ 10:11 am
k genika pws sou fainontai ta knobakia tou mikth gia ta EQ, alla kai ta faders einai arketa makria?
gt skeftomai n parw ton DN X-1100 ths denon, pou ap oti vlepw exw paromoia knobakia k diataxh. opote m endiaferei mia gnwmh sxetika me thn xrhstikothta tou...
http://www.denondj.com/DN-X1100-P107.aspx
geposted Fri 31 Dec 10 @ 10:24 am
geposted Fri 31 Dec 10 @ 10:30 am
Δες το video απο πάνω... Πάντως ο μίκτης που θέλεις έχει μακρύτερα upfaders (6 εκατοστά) και το ίδιο crossfader (4.5 εκατοστά)
H MC-6000 έχει 4.5εκ upfaders και 4.5εκ crossfader.
Τα pitch slider πρέπει να είναι 6 ή 8 εκ αλλά θα το ξανακοιτάξω το βράδυ
geposted Fri 31 Dec 10 @ 10:45 am
wraios phantom!
s eyxaristw poly
s eyxaristw poly
geposted Fri 31 Dec 10 @ 11:38 am
psinomai gia thn dennon .... thanx gia to review perimenw kai tis leptomeries gia ton hxo
geposted Sun 02 Jan 11 @ 11:40 am
Δουλεύω και σήμερα το βράδυ...
Αύριο το πρωί θα κάνω ξεχωριστό νήμα με αρκετές φώτο καθώς και μερικά ακόμα βιντεάκια και με τις συνολικές εντυπώσεις μου.
Πάντως θα πω μόνο οτι μετά απο 4 βραδιές συνύπαρξης με την DENON, ΟΧΙ ΔΕΝ μετανοιώνω ούτε για την αγορά μου, ούτε για τα λεφτά που έδωσα... Τα υπόλοιπα θα τα απούμε αύριο!
geposted Sun 02 Jan 11 @ 1:35 pm
Tote tha prepei na metonomasoume to topic se million dollar answer ..:D
geposted Sun 02 Jan 11 @ 5:34 pm
Lefta yparxoun... (Pou pigan ta lerfta" ..?)
geposted Sun 02 Jan 11 @ 7:37 pm
