its saying i need the right driver, have tried multiple drivers which should work... im using a dell inspiron, im trying to use virtual dj v6.1.2 its saying the same problem with traktor scratch pro also... anyone else get this problem? its brand new aswell, help would be great :)
geposted Tue 07 Dec 10 @ 1:04 pm
As your shown as an LE user, can I presume that you have installed the version of VirtualDJ that came with the controller. The version you should have had with your controller is setup to work, out of the box, with your controller. Other versions of Virtual DJ (except PRO) will probably not recognise your controller, as controller usage is unique to Pro (although a 10 min trial is available in HOME edition as well - I think)
If you are, then the following may help.
I am not familiar with the MixDeck, but would ask, did it come with a driver disk? The DJ Steel I have did come with a driver disc.
Try this:
1) with your Dell running, plug in your controller (windows should recognise a USB device plugged in and make that annoying BING sound)
2) start VirtualDJ
3) click on "Config"
4) click on the "Mappers" tab.
in the drop down box, your controller, if connected correctly, should be listed. If not, click on the button to the right of the drop down box and select "Rescan for new devices) and see if VDJ picks up your controller.
Try this:
2) start VirtualDJ
geposted Wed 08 Dec 10 @ 4:52 am
i cant start up virtual dj until the controller is recognised, when i try to start it up it says, controller has not been detected, please plug it in and start up virtual dj again
geposted Wed 08 Dec 10 @ 2:59 pm
i guess it would also help to say im using vista, ive tested tested it on an identical laptop with windows 7 and it works, ive also tried it on an identical laptop with vista again and it has the same problem, do you think its vista or the midi? it picks it up every so often, ive actually used it for about 10 minutes before its become unresponsive...
geposted Wed 08 Dec 10 @ 3:04 pm
Jon, I make no claims to be an expert in the compatibility of VDJ with Vista, but as a pro coder of 20+ years, I would never entertain Vista.
Vista was so bad that even Microsoft offered "downgrades" to XP for some licences - I have an in-car PC kicking about somewhere, that I downgraded from Vista to XP.
Sorry I can't offer more help.
geposted Wed 08 Dec 10 @ 4:30 pm
i couldnt agree more, i shouldnt really expect the virtual dj side of things to be putting ideas out anyway to be honest, i'll take this problem to numark instead for misguiding me to buy this product with the illusion it would work on my laptop, ill be downgrading shortly if they cant give me help soon, thanks for all the help
geposted Wed 08 Dec 10 @ 5:21 pm
That's weird, I've had Vista 64 for quite a while and haven't had big problems. I always d/l the windows updates and also I don't install any of the "toolbars" out there that so easily get in your system everytime you sneeze.
I hope I didn't just jynxed myself.
lol
lol
geposted Thu 09 Dec 10 @ 8:25 am
I run audio & video on with a Behringer BD2000 & v5.07 on Vista 32bit no problems. Also I run a Hercules RMX, & (2) Numark V7's with VDJ v7.0.1 on Vista 32bit on my main Acer & backup Gateway laptop without any problems.
geposted Sun 12 Dec 10 @ 4:43 pm
the problems with the mixtrack, they are working on a permenant solution
geposted Mon 20 Dec 10 @ 4:02 pm
I got Mixtrack Pro and im running XP, and im having the same problem, £200 wasted if i dont sort it.
geposted Thu 23 Dec 10 @ 7:14 pm
I am having the same problem. It says the controller is nt recognized and it wont load up. It loads up in my vista laptop with no problem but wont load on XP. Any suggestions???????????
geposted Wed 05 Jan 11 @ 4:18 pm
Hi there.
I have helped out a couple of other users in the forums with the exact same issue using Denon controllers. For the last several posts, is this problem happening with your default OS that came with your laptop or computer? This issue is directly related to a driver and/or a firmware update.
Let me know the specs and the installed os and if it is the default os or not.
Cheers
Djwishbone
Cheers
Djwishbone
geposted Thu 06 Jan 11 @ 5:28 am
