I've been searching everywhere on here and it seems like no one knows the original default pattern.
If someone does know I would appreciate it so very much.
Thanks in advanced!
Added by SBDJ for clarity:
This is the original Beatgrid preset 1 which is what most people will want:
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
Failing that BeatGrid.ini should look like this:
Thanks in advanced!
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
[Preset1]
MicroGrid=1
Mode=0
Grid=0000000000000000000000000000000001000000FFFFFFFF010000000100000002000000FFFFFFFF02000000FFFFFFFF03000000FFFFFFFFFFFFFFFFFFFFFFFFF2
[Preset2]
MicroGrid=1
Mode=0
Grid=00000000FFFFFFFFFFFFFFFFFFFFFFFF01000000FFFFFFFFFFFFFFFFFFFFFFFF02000000FFFFFFFFFFFFFFFFFFFFFFFF03000000FFFFFFFFFFFFFFFFFFFFFFFFD6
[Preset3]
MicroGrid=1
Mode=0
[Preset4]
MicroGrid=1
Mode=0
geposted Wed 08 Dec 10 @ 11:24 am
Just delete beatgrid.ini from the SoundEffect plugins folder whilst VDJ isn't running.
geposted Wed 08 Dec 10 @ 11:39 am
Didn't help. I just really want the original config as one of my beat presets.
geposted Wed 08 Dec 10 @ 11:49 am
OK:
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
geposted Wed 08 Dec 10 @ 6:13 pm
Thanks! Big Help!
geposted Wed 08 Dec 10 @ 10:38 pm
man ur awesome thanks alot my beatgrid finally sounds good again :D
geposted Tue 19 Apr 11 @ 6:12 am
while we are on the topic of the beatgrid, Is it possible to map the pattern buttons off the effect to a key eg.
deck 1 effect 'beatgrid' active & effect 'beatgrid' pattern 2
I know you can map sliders, but not sure about buttons
Cheers
Cheers
geposted Tue 19 Apr 11 @ 7:27 am
Sorry, this is not possible.
Beatgrid uses a custom GUI and does not support MIDI mapping (Except for turning the effect on/off.)
geposted Tue 19 Apr 11 @ 5:27 pm
hola algien me puede decir como descargo beatgrid effecto de sonido gratis es q el tenia no se q le paso se daño creo
geposted Thu 28 Apr 11 @ 10:58 am
Sorry, this forum is for English language messages only. Please either post your message again in English or post in the appropriate language forum at the bottom of http://www.virtualdj.com/forums
geposted Thu 28 Apr 11 @ 11:24 am
Cheers
Cheers
Im not completely sure about this, but i think you could make a copy of the beatgrid dll file in the plugins folder, that way making virtualDJ see the two files as two different plugins, with different settings. That way you can have two different patterns, and map each to a button. Not 100% sure this would work though..
geposted Sun 01 May 11 @ 2:06 pm
You Sir are a genius, that should work :)
geposted Sun 01 May 11 @ 3:40 pm
OK:
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
Where/How do i imutthat cause my beat grid config ooks different VDJ 7
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
geposted Thu 09 Jun 11 @ 9:24 pm
Click on the MICRO-GRID button (Effect page->Sound effect tab->beatgrid)
geposted Thu 09 Jun 11 @ 9:59 pm
It transpires Preset1 was missing from my beatgrid.ini. You should be able to select the grid options as described above and when happy save the options using the small circular buttons on the right - most of us will just want to use the upper right button.
Alternatively you can copy the text below into your beatgrid.ini file....
[Preset1]
MicroGrid=1
Mode=0
[Preset2]
MicroGrid=1
Mode=0
[Preset3]
MicroGrid=1
Mode=0
[Preset4]
MicroGrid=1
Mode=0
geposted Thu 16 Jun 11 @ 4:12 pm
i just got this program and was messing around with the beat grid how can i set it back to the original??
geposted Thu 29 Sep 11 @ 4:22 pm
It pays to read the thread before posting...........
SBDJ wrote :
OK:
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
D=DOWN
U=UP
DDDD UUUU UUUU UUUU
UUUU DUDD UUUU UUUU
UUUU UUUU DUDU UUUU
UUUU UUUU UUUU DUUU
geposted Fri 30 Sep 11 @ 4:23 am
dont be a jerk
geposted Mon 17 Oct 11 @ 11:19 am
how is huey being a jerk? he simply said what the poster should have figured out from reading the post, the question is why did you feel the need to bump a thread that was dormant for a month, and not add anything to the topic..
geposted Mon 17 Oct 11 @ 11:26 am
Indeed.
It also has nothing to do with the person who posted that comment.
The information requested is in this thread, so I will highlight it better and then lock this thread and it can serve as reference.
geposted Mon 17 Oct 11 @ 2:09 pm
