Forum: Old versions
Topic: vdj 7 and vestax typhoon problem
Hi I am using vdj 7.01 and virtual vinyl 6.12 and i am getting to use it on virtual vinyl but not virtual dj 7.01 please help me anyway possibly
geposted Wed 08 Dec 10 @ 8:41 pm
The Typhoon is only natively supported in VirtualDJ v7.0 and above.
It would only be working in VirtualVinyl v6.1.2 if you have installed a custom definition and mapper (Check the folders My Documents\VirtualDJ\Devices and My Documents\VirtualDJ\Mappers to see if this is the case), or it's possible that it being detected as the Spin.
Unless you have unusual firmware, it should be detected and used automatically in v7.0.1
If this is not the case, please download the tool https://virtualdj.com/download/miditrace.exe and run it with VirtualDJ and all other applications closed. Choose the Typhoon in both sections to the right and click SEND. Copy and paste the resulting output in your reply.
