Denon says just under 5 kilos (4,7) for the DN-MC6000
And the 2000 just over 1 kilo (1,3) so add up two controllers and a mixer you easy hit 5 kilos or just above.
geposted Wed 22 Dec 10 @ 7:39 am
Ok fellas who already have the unit and plan on makin a video..................we already now what features it has. We all have read the same sites, manuals, etc.etc.......so how about a quick mix then tells us how it feels, like if things to close or not enough of this or that. How comfortable you feel when using it.
Thanks for the time and info
Huey
Huey
geposted Wed 22 Dec 10 @ 7:49 am
this is my setup.. i have the denon 4500 with numark c3 usb and a flight ready case... i love my setup but i would definately sell it for the mc 6000... if anyone interesed.. let me know
geposted Wed 22 Dec 10 @ 11:11 am
Here's a short but good youtube vid ....
http://www.youtube.com/watch?v=Z3Kga0snKGc
geposted Wed 22 Dec 10 @ 1:30 pm
i just bought the MC-6000 12pm today had only about 1 hour to play with it. From the moment i unboxed and plugged it in I was running inside of 3 minutes. using mbp
I to say Denon and VDJ you guys hit a home run with this controller. i will write a review later on.
pics
http://www.flickr.com/photos/36179413@N07/5283851240/in/photostream/
http://www.flickr.com/photos/36179413@N07/5283252139/in/photostream/
http://www.flickr.com/photos/36179413@N07/5283251421/in/photostream/
http://www.flickr.com/photos/36179413@N07/5283848402/in/photostream/
http://www.flickr.com/photos/36179413@N07/5283249125/in/photostream/
pics
geposted Wed 22 Dec 10 @ 3:30 pm
There are a few other vids on YT with the 6000 being used with that farm equipment program. I'm Looking forward to more VDJ/6000 videos!
geposted Wed 22 Dec 10 @ 3:59 pm
Thinkin about buying this controller... I would like to have a very compact and portable rack mount for it, do you think that this fits?
http://www.thomann.de/fi/thon_rack_4_he_economy.htm
or this?
http://www.thomann.de/gb/thon_rack_4he_eco_ii_compact.htm
or this?
geposted Wed 22 Dec 10 @ 4:52 pm
I don't think either of those will work
geposted Wed 22 Dec 10 @ 5:06 pm
Both of those cases are too deep. You don't need that.
geposted Wed 22 Dec 10 @ 6:51 pm
*This is for all the users that are using VirtualDJ with a 2 deck skin using the INT MIX mode. By the way I strongly suggest using the external mix mode for the lowest latency
So here goes, in config under sound setup your settings should be as follows.
Inputs - None
Outputs - External Mixer
Soundcard ASIO - then choose the Denon ASIO driver.
Now make sure that the CF mode is set to video only. If it is on audio you will run into problems. The way VirtualDJ is routed it will be using channel 2 and 3 on the MC6000. So set 2 and 3 to midi. 1 and 4 can be set to your line 1 and line 2 for external sources.
Last but not least the most important step. Go into config again. Locate the mappers tab. Make sure the Denon DN-MC6000 is listed in the drop down menu. Locate volume in the list of actions and click on it. Now in the action box to the right delete the word VOLUME. Click Ok and close the config menu.
You should be all set. Now when going back to a 4 deck environment simply go back in and click volume under mappers and write volume in the action box.
Hope this helps!!
Or just grab the mapper :P
http://www.virtualdj.com/addons/12429/Denon_DN-MC6000.html
Inputs - None
Hope this helps!!
geposted Wed 22 Dec 10 @ 8:38 pm
Im just about to leave my house to go grocery shopping now. I'm gonna get vegetables, some chicken fillet, apple juice... oh and a DNMC6000. :D
geposted Thu 23 Dec 10 @ 2:37 am
or this?
or this?
geposted Thu 23 Dec 10 @ 7:25 am
Nicely put tohether
http://www.youtube.com/watch?v=zAxDEr5t_U8
geposted Thu 23 Dec 10 @ 7:47 am
Odyssey case looks cool but also too deep as well as all the other cases I've seen, or is the cover part underneath the case in the pic?
How do I get one of those to northern europe?
geposted Thu 23 Dec 10 @ 9:29 am
Hey I purchased the DNMC6000. Now how do I register it on the website and get a nice little picture of it beside my name???
geposted Thu 23 Dec 10 @ 12:28 pm
Go to modify my profile and you can add the serial there.
geposted Thu 23 Dec 10 @ 1:07 pm
Great short Video mix by DJ Big Daddy, enjoy!
http://www.youtube.com/watch?v=wlUqb39B2BU
geposted Thu 23 Dec 10 @ 2:39 pm
I live in asia, so my unit came with traktor L.E instead of VDJ L.E. I tried entering the serial number of the DNMC6000 in there but it said "invalid serial".
geposted Thu 23 Dec 10 @ 2:52 pm
Check if you entered it correct - Serial has the format: XXXX-XXXX-XXXXX That's it.
Greets, Heiko
Greets, Heiko
geposted Thu 23 Dec 10 @ 3:40 pm
Ah ok well then the LE serial would be for Traktor not VirtualDJ.
geposted Thu 23 Dec 10 @ 3:53 pm
