I'm importing my titles into the database. I've attempted to use the ID3 tag mode and just straight pulling files in by name. Regardless of the way I import, 60% of my songs all display this same artist/track label. Anyone else seen this problem?
Thanks in advance!
Eric
Thanks in advance!
Eric
geposted Mon 04 Jul 05 @ 6:43 pm
I had a similar problem...but for me it was only for a few songs..so i right-clicked, and then clicked RENAME and then typed the track name, etc even though they were still there...
That solved the problem. But if this doesnt work, try switching off the READ ID3 tags option, and then restart vdj and then Switch that option on again.
Lastly, make sure your tags are perfect, use a good tagging software like Tag&Rename...
Let us know...
regards,
aditya
Let us know...
regards,
aditya
geposted Tue 05 Jul 05 @ 10:38 am
I use Flash Renamer. I can't live without it.
geposted Tue 05 Jul 05 @ 1:12 pm
reinstall VDJ
another user had this issue.
A reinstall fixed all
geposted Wed 06 Jul 05 @ 12:26 am
I'm re-installing now as I type. I've been a HUGE advocate of Tag&Rename for almost 2 years, this program ROCKS! I'll post here shortly and let you know how the re-install goes.
Thanks-
Eric
Thanks-
Eric
geposted Wed 06 Jul 05 @ 2:32 am
That did the trick. However, It looks like I need to go back through and re-do some of my ID3 tags. What program will completely remove any tagging from a file?
Thanks.
Eric
Thanks.
Eric
geposted Thu 07 Jul 05 @ 6:25 am
doesn't Tag&Rename support that?
think it has a feature for removing tags as well, if I dont remember wrong
geposted Thu 07 Jul 05 @ 2:39 pm
Id3kill will "kill" all your tags in seconds....
http://www.headstrong.de/
freeware
freeware
geposted Thu 07 Jul 05 @ 4:22 pm
