Using that with ASIO drivers with TCV's, yes or no? If I'll have to buy a Maya card or not...
geposted Tue 05 Jul 05 @ 1:34 pm
As far as I known, the SB Audigy 2 NX USB don't allow to use 2 stereo input and 2 stereo outputs simultaneusly with ASIO drivers... I said no, it doesn't works. But give it a try, if it doesn't work go to the next option.
The maya 44 works fine with VDJ. I said "yes" buy it.
geposted Tue 05 Jul 05 @ 7:51 pm
Thank you! :)
geposted Tue 05 Jul 05 @ 9:14 pm
