Instead of three cues per side. Make it six per side total, this would allow more creativity utilizing hit cues.
geposted Thu 16 Dec 10 @ 8:38 am
You won't ever reach VDJs hotcue limit. The limit you are referring to is simply a skin choice so as to not clutter the screen.
Use a different skin, edit the skin or map some controls.
geposted Thu 16 Dec 10 @ 9:14 am
Thanks for the info. I'm learning more everyday on here
geposted Thu 16 Dec 10 @ 1:32 pm
There are 99 cue points that can be set. As SBDJ stated the 3 is a common skin selection.
You can use VDJScript with controllers, keyboard, etc to set beyond 3 -- set_cue # where # is the number (4,5,6,...,99) you want to create.
You can also name your cue points with a VDJScript like this -> set_cue 99 & cue_name 99 "Mix Out"
geposted Thu 16 Dec 10 @ 2:41 pm
