1) Is anybody using the iPod Touch as a remote device for VDJ?
2) Is anybody designing skins for the iPod Touch?
and
3) If someone does design skins for the iPod Touch how would I download or install the skin on my iPod Touch?
Thanks in advance for any and all answers....PEACE!
p.s. I can browse the internet from my iPod touch but I can't download skins from vdj website.....just wondering how I would if skins were made available...
and
geposted Sat 18 Dec 10 @ 3:21 pm
1. Yes i'm using it with an ipod touch 2nd gen, and the same skins for the iPhone can be used with the iPod
2. you download the skin of your choice, inside the Virtual DJ folder, go into skins and make a folder named "iPhone"
now install like a regular skin.
open VDJ pro and go to the iPhone/iPad tab.
connect your device, and upload new skin. you should see the skin you downloaded in the iPhone folder you created. and Voila, its on your iPod.
geposted Sun 19 Dec 10 @ 12:09 am
