I would like to know if it's possible to put a Mixman DM2 controller, or any way to get it works with VirtualDj software ? They are really cheap, I can buy one for 25$ can , and they seams to be enough for a bit mre fun !
http://www.mixvibes.com/hardeng.htm
http://www.mixman.com/products/hardware.html
Tanx
Tanx
geposted Thu 07 Jul 05 @ 5:42 pm
I have one of those Mixmans (mixmen?) lying around and when I used it in the past (not with VDJ,) I remember there being a program that maps all of its controls to MIDI. Wiith that installed, you should be able to then map it as any MIDI device.
Let us know how it works... maybe I'll try using mine ;)
geposted Thu 07 Jul 05 @ 10:56 pm
i believe you can map everything but the jog wheels so it no very useful
geposted Fri 08 Jul 05 @ 4:22 pm
Get the program "dm2 to midi" from pdoom! That program will enable you to map Midi events to the dm2!!
I made a setup for this with files for dm2tomidi and Virtual DJ (Shortcut & Skin).
I uploaded that setup file to the skin section here ... dunno know if it is downloadable so...
It's quite a workable setup --- i tested it alot and its FUNctional !!!!
geposted Fri 19 Aug 05 @ 8:06 pm
upload it somewhere because i can't find it on virtualdj's website. or email it to me at --@--.-- . thanks in advance
Moderated by Lady Cameron
Sorry c76n45 no email address is allowed from a demo user
geposted Sat 21 Jan 06 @ 2:06 pm
