I am a mobile dj who does weddings birthdays etc. I need a skin with a large browser, 2 decks, play n pause, pitch control, time lapsed, separate volumes, gain control, 3 band equalizer and a clock - everything else is probably too advanced for what I need to do with it! I am going to try and edit an existing skin and .xml file (if that's ok/legal?) my question is, is there a chance of me cocking it up and causing VDJ to crash during a gig? and should I stick with the one I've got? I have read the guides and feel that I should give it a go. Anyone? Maybe someone has a skin already. The ones I've downloaded already are not quite suitable for me. Cheers, Craig.
geposted Thu 07 Jul 05 @ 10:26 pm
Craig,
I'll build it for you, if you like?
Go to my blog and email me. If you have a starter graphic that would be cool. But I can start from anywhere. Let me know what resolution you want it at also.
cstoll
cstoll
geposted Fri 08 Jul 05 @ 1:14 am
Yes it is legal !!!
it is an section to help you with your skin
https://virtualdj.com/support/developers/skin.html
and after , you can put your new skin in your skin download section
https://virtualdj.com/addons/view.html?type=skin
geposted Fri 08 Jul 05 @ 1:53 am
and the risk of crash are minimal, VDJ scan the new skin file to check if it is OK
I Sujest you to test your skin befor make a gig with.
you can see the other skin to help you
geposted Fri 08 Jul 05 @ 1:55 am
cstoll
That would be fantastic!
I use the advanced default one at the moment. I will try and get a starter graphic and e-mail it to you. The resolution would be 1024x768 I think (will double check). Thanks again cstoll!
VDJ amazes me every time I use it! Cheers guys
geposted Fri 08 Jul 05 @ 2:04 pm
geposted Fri 08 Jul 05 @ 9:36 pm
