Hello everybody,
I have a wish for a new feature. Currently it is easy to save up to 10 cue points no problem, but I was wondering why VDJ hasn't added the feature to save loops that all you have to do is turn the loop "on" somewhere during the desired loop (as in you preset the start and end of the loop and if you miss your exact point it doesn't matter) like in serato. I understand that with the smart loops this isn't entirely necessary, but I think it may be a nice little back up feature in case you miss that all important loop entry point.
Cheers,
DJ Alpaca
Cheers,
DJ Alpaca
geposted Thu 23 Dec 10 @ 10:08 pm
i agree ... new feature save loops...
geposted Thu 27 Jan 11 @ 4:28 pm
you can already do that in vdj script... This script works really well as it uses the same button to start the hot loop and exit the loop when pressed again... This is the code you will need
deck (#) loop ? deck (#) loop_out : deck 1 hot_cue (#) & deck (#) loop (#)
eg. deck 1 loop ? deck 1 loop_out : deck 1 hot_cue 10 & deck 1 loop 4
and if you have an endless rotary encoder or set up a couple of buttons you can change the loop length once the loop has started, but remember if you wanted to delete the hot loop you would have to set up a button... I got really fancy and made it so you would press it once to set or activate the hot cue and the loop, press it twice to end the loop, and hold it for a second to delete the hot cue... all the same button! Can serato do that? LOL
for the button:
holding 1000ms ? deck 1 delete_cue 10 : deck 1 loop ? deck 1 loop_out : deck 1 hot_cue 10 & deck 1 loop 4
for an endless encoder if you want to have one knob for each deck just put deck # in front of the loop:
param_greater 0 ? loop_double : loop_half
enjoy
for the button:
enjoy
geposted Fri 11 Mar 11 @ 5:52 pm
for the button:
enjoy
for the button:
enjoy
The power of VDJ Script is genius!!
Freaking superb!!
geposted Fri 10 Jun 11 @ 5:17 pm
Tried the script.. its perfect for what you wanted it to do but my suggestion is to 1) assign a shift button 2) make cue point buttons 3) assign a loop 4/loop out button. my set up.. (Shift) - (cues) 1-12 6 buttons 6 unshifted 6 shifted - (loop 4) or 2, if looped loop out - and finally a knob for loop 1/18 1 2 4 8 16. does that make sense? make jog wheels loop move and its loop heaven.
geposted Sat 23 Jul 11 @ 2:25 pm
Major +1 right here.
geposted Wed 03 Aug 11 @ 3:20 pm
