What do i need to use my headphones and listen to the music on my speakers at the same time? Sorry if this is a question ya'll get a lot but i just cant figure it out.
geposted Fri 08 Jul 05 @ 8:20 pm
sorry this isn't possible in the demo version
geposted Fri 08 Jul 05 @ 8:27 pm
I have the full version,not the demo version.
geposted Fri 08 Jul 05 @ 11:42 pm
Please add the serial number to your profile to reflect that.
MS
MS
geposted Sat 09 Jul 05 @ 12:12 am
hey I need to be able to cue the music with the music I'm gonna mix in the headphone? Who makes a (DJ) program that not allows for this? this is DUMB. fix this problem. I need to hear both the music and the cue.
geposted Sat 09 Jul 05 @ 11:04 pm
Say what? Ofcourse you can cue/play/mix/whatever while prelistening on your headphones. You sure you got the settings correctly?
geposted Sun 10 Jul 05 @ 12:26 am
Perhaps he lacks a 3D soundcard.., in which case you can get a splitter, but 3D soundcard is the best solution.
geposted Sun 10 Jul 05 @ 12:40 am
3D sound card? okay I will look for one... any suggestions on where I can get one? however it did word for the other program that came with the console. by the way I am using the Hercules Console
geposted Sun 10 Jul 05 @ 7:49 pm
The Herc Console allows u to preview tracks using the headphone socket, make sure ur lil green alien icon is set to "DJ" mode first
geposted Mon 11 Jul 05 @ 12:27 am
IT IS SET TO DJ MODE, BUT IT STILL NOT ALLOWING ME TO MONITOR BOTH OF THEM AT THE SAME TIME?
geposted Thu 14 Jul 05 @ 5:11 am
Stop shouting, please. ;-)
Try a skin with a headphone-mix slider. Jim Nordic´s do have such. Or as an skin independent alternative, create keyboard shortcuts for the headphone_mix value.
geposted Thu 14 Jul 05 @ 1:43 pm
hi, same as anyone on ere how do i get my headphones working like a real monitor, like you have on a real set of decks. got most of the skins just a simple answer will do.. i have two sound cards. anyone on here from soundlive 2002.... ron
geposted Sat 01 Oct 05 @ 6:13 am
You could get the proper operation of headphones with the full version. Sorry. VirtualDJ works with 2 Sound Cards or just one 5.1 soundcard. But it has to be the purchased version of VDJ.
Good Luck!
Good Luck!
geposted Sat 01 Oct 05 @ 7:53 am
I am currently in iraq deployed so i dont have the ability to get new soundcard especially for my laptop. i undertstand you can use a headphone splitter does anyone know exactlly which kind... stereo or mono... my instincts would tell me mono so one channel thru one jack and other thru second... if no one knows i'll have my wife send both... thanks
geposted Sun 02 Oct 05 @ 12:33 am
Is better to get a 5.1 USB sound card. But If you don't be able to do that the spliter takes a mono signal. One for the amp (in mono) and one for the headphones (in mono too).
geposted Sun 02 Oct 05 @ 1:24 am
well i currently plan on getting a usb soundcard when i return to the states but now i will work with mono splitter
geposted Sun 02 Oct 05 @ 5:49 am
I am having video quality difficulty. How can I improve the quality of a brand new laptop with a kicking video card that is now playing videos much quicker but with poorer video quality?
geposted Mon 03 Oct 05 @ 4:43 am
Rick Danger,
Search in the forum, and use a proper topic, this is "Using headphones".
geposted Mon 03 Oct 05 @ 6:00 pm
think this is all kind of funny i have two sound cards one that goes into my internet part and a usb card i have had trouble with heasphones can i use the sound card that does not need to be in the usb and still get headphones im getting confused i tried going through the settings but it doesnt seem to pick up the headpohnes are my settings correct.... i have a prodigy soundblaster card
geposted Fri 07 Oct 05 @ 2:35 am
Apricorn,
I'm not sure about your model of Sound Blaster card, but check My blog, I have a setup instructions for Sound Blaster Sound Cards and Headphones use. It could be useful.
geposted Fri 07 Oct 05 @ 2:45 pm
