Forum: Old versions
Topic: Hercules RMX Question
I was interested in picking the RMX up for not only DJing onsite but at home over the internet. My question is Can i use the RMX to broadcast online with a headset and a mic? or can i not use it unless it is connected to amp/speakers? please let me know before i go shopping! and if not can you suggest a product that would allow me to do this.
geposted Sat 25 Dec 10 @ 5:59 pm
si se puede!
You dont need speakers and amplifier to broadcast.
But you will need VirtualDJ Prof Full Version
https://virtualdj.com/buy/
Once you buy the RMX which is bundled with VirtualDJLE , register the serial number of the LE and you will be able to get a discount for the Pro version
Note also that the Broadcaster Version (which is also available) will not let you use the RMX
See the Comparisson chart
https://virtualdj.com/products/comparison.html
