I want my profile to be recognize as a HDJ CONSOLE user. I disable the firewall on my computer, I then went to MODIFY MY PROFILE, I clicked on DJ CONSOLE DETECTION and I get a message that states that it can't detect my console edition. What am I doing wrong?
geposted Sat 09 Jul 05 @ 1:00 am
Are you using a router?
geposted Sat 09 Jul 05 @ 10:10 am
I'm not sure, but I think you will need to install the console edition of vdj before you can detect youre dj console.
Can somebody confirm this?
geposted Sat 09 Jul 05 @ 12:10 pm
@dasouth2004
I don't think so
I don't think so
geposted Sat 09 Jul 05 @ 3:11 pm
you need to run vdj as well when detecting your console online I believe...
geposted Sat 09 Jul 05 @ 5:48 pm
Yes, I'm going thru a router and yes I have VDJ running when I try to have my console detected.
geposted Sun 10 Jul 05 @ 2:06 am
Try connect directly to the internet when detecting. I don't think it will recognize it otherwise, cause of the router.
geposted Sun 10 Jul 05 @ 10:22 am
Naaah, lets make it correctly from the start.
Which port do we need to forward in our FWs/Routers?
geposted Tue 12 Jul 05 @ 5:53 pm
you are ALL full version users...
to have VDJ server recognize you as a CONSOLE user and give you "console user" forum tag, you need to run the CONSOLE VERSION exe file, when logged into your profile at VDJ forum.
The FULL VERSION exe file will NOT be detected as console user (tag at forum), even if the console is connected...
hope that helps
(btw - the vdj console exe file is at the hercules install disk that came with the console)
hope that helps
geposted Wed 13 Jul 05 @ 4:09 am
just like I tought :)
geposted Wed 13 Jul 05 @ 8:09 pm
