Greetings. I have a Mac Book Pro, 2 cdj-400s, and VDJ-7. I figured out a remedy for the single soundcard issue (use "advanced config"), but I can't get the two units to control the decks independently. What ever I push on one CDJ it mirrors on the other.(i.e. if CDJ 1 is on deck 1 then CDJ 2 is on deck 1). How can I fix this. Thanx for you help.
geposted Thu 30 Dec 10 @ 9:27 am
Go to CONFIG -> Mappers, click on the button to the right of the drop-down list and choose Deck Assignments
From there you can assign each CDJ to the correct deck.
Or press the EJECT button on each player to toggle it to the appropriate deck.
Make sure that you have the latest VirtualDJ v7.0.2 Pro installed: https://virtualdj.com/download/updates.html
geposted Thu 30 Dec 10 @ 10:15 am
