CAN ANYONE OF YOU...CAN GIVE THE EXACT STEP..HOW TO REMOVE>>THIS ERROR>>IT IRRITATES ME...pLs..helP..me
geposted Thu 30 Dec 10 @ 11:58 am
The most common cause of this error is installing the software while logged in as one user (E.g: Fred) and then trying to run it as a different user (E.g: Joe.)
The other user is missing the My Documents\VirtualDJ folder. The program will not run without this.
To resolve, please either:
(1) Install the software as the user you will be running it as.
(2) Manually copy the My Documents\VirtualDJ folder across to the other user.
Another cause is installing the software without administrator privileges under Vista or Windows 7. Right-click on the VirtualDJ installation file and choose Run as administrator. Also, we would recommend turning off UAC in Windows Vista and 7: http://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista
geposted Thu 30 Dec 10 @ 11:59 am
..THANKS...Ure..THING HELPS>.AbOUT..THE SKIN...BUT>..aNotHER PROBLEM..IS "PROTECTION ERROR ^"...whats..this??? pLSS HELP...
geposted Thu 30 Dec 10 @ 1:09 pm
Please contact support for assistance with this problem:
https://virtualdj.com/contact/
geposted Fri 31 Dec 10 @ 4:06 am
Perfect thanks
geposted Mon 03 Jan 11 @ 5:10 am
