Hi all. I'm really desesperate, since the v7 I have freeze when I'm Djing. Mostely 1 or two times in the night. All stop and the only way to have back VDJ running is to disconnect my RMX and replug the USB connector.
I have try all what I can do and it happend only with the 7.x versions
Somone with the same problem ? Any solution ?
Thanks in advance
Material and soft info here: https://virtualdj.com/homepage/spider66/blogs/2914/My_Material.html
Thanks in advance
geposted Sat 01 Jan 11 @ 7:43 pm
Mine does the same but only stop for a second or two then comes back very annoying trying to trouble shoot first i tried the connect from drive to computer that didn't work now i'm about to see if it may be the virus protector. does any one have crashes when you open some effects and and task manager?
geposted Fri 07 Jan 11 @ 10:40 am
I'm having the same issue, it seems to totally freeze when i load songs virtualdj's never played before. it only does it the first time but it's very disconcerting.
geposted Sat 08 Jan 11 @ 3:20 am
I have had a couple of issues of white noise (like a bad tuned FM radio) No warning just goes from playing track to white noise I then have to close VDJ and re open it and it works fine again. Any help would be good. I use a brand new Sony Vaio with win7 64bit and 6 gig Ram. With a 1tb HD and have an RMX linked to it.
Cheers
Nik
Cheers
Nik
geposted Sun 09 Jan 11 @ 1:46 am
i have the same issue i just load a cd and reboot the vdj 7
geposted Sun 09 Jan 11 @ 4:51 pm
all u guys have updated the drivers?
geposted Mon 10 Jan 11 @ 4:30 pm
