With the IQ2 MIDI Reloop presents the latest mixer from the trend-setting IQ series. Compared to its predecessors the IQ2 MIDI is completely digital with the best, noise-free sound characteristics and a 4x4 multichannel USB audio interface with 24 bit / 96 kHz studio quality. As all elements are MIDI compatible this mixer can also be used as MIDI controller and thanks to the MIDI flex function, the crossfader, as well as the effect unit, can be used in MIDI or audio mode. Moreover the IQ2 MIDI offers a digital matrix-input function. This way all audio inputs, as well as all MIDI channels, can be flexibly routed to the channels. The ASIO/CORE audio drivers guarantee the absolutely lowest latency for a professional standard while mixing. Further novelties are the reversible crossfader and the 2 battle mode that allows looping in a second mixer or DVS system via the loop input. Topping it all off is the fact that the mixer is (Other Software Ready) and it can be selected very easily within the software as preset. No matter if digital DJ, turntablist or electro clubber this mixing talent does not leave anything to wish for.
features:
2+1 channel PRO DSP mixer with USB terminal
New - Best, noise-free sound: internal signal processing is completely digital
New - Integrated multichannel USB audio interface: Hi-speed 4x4 In/Out interface with 24 bit/96 kHz sound quality
New - Full MIDI control: All elements are MIDI compatible
New - MIDI flex: Crossfader and FX unit can be used in MIDI or AUDIO mode
New - Lowest latency: Incl. professional ASIO/CORE audio drivers
New - Digital matrix input: All inputs, as well as all MIDI channels, can be flexibly routed to the channels
New - Master cue: Cuts and scratches can be monitored via headphones
New - XF flex: Reversible crossfader
New - 2 battle mode: Via loop-in a second mixer or DVS sytem can be looped in
> Full Duplex USB port for feeding and emitting digital sound signals
> USB signals can be played via mixer and recorded on a computer simultaneously
> 3 innovative crossfader effects (LoopX, PitchX, StutterX) with manual or automatic cross-fade
> Freely assignable DSP effect unit (Echo, Auto Pan, Flanger, Manual Filter, Auto Filter, Reverb, Trans, Pitch Shifter)
> Manual filter infinitely adjustable from LPF - HPF
> Time regulation for X parameter, dry/wet regulation for Y parameter (as mini fader)
> Manual beat and time assignment of effects with 5 buttons
> Automatic and manual beatcounter
> Effect send/return for both channels
> Excellent sound characteristics due to Premium Sound Architecture (PSA)
> Top panel with rubber paint finish, low panel made of brush-finished aluminum
> Freely assignable Long Life TCT crossfader (45 mm) with adjustable curve
> Long Life linefader (60 mm) with adjustable curve
> Fader start play for linefaders or crossfader
> Large LCD display for all effect and BPM parameters
> 3-band equalizer for channels 1 and 2
> 2-band equalizer and talkover for microphone
> Master volume with especially large vintage potentiometer
> iPod friendly AUX input on the front side
> 2 headphones connections (3,5 and 6,3 mm)
> Symmetrical (6,3 mm jack) as well as asymmetrical (RCA) outputs
> PC & Mac compatible
geposted Mon 03 Jan 11 @ 9:44 am
Can the crossfader on this mixer be used for videos and audio simultaneously?
In terms of price it is much cheaper than the Pioneer DJM-800 which is above my budget.
geposted Tue 03 May 11 @ 8:53 am
Does this mixer actually work as MIDI? If you move the sliders, do the sliders in Vdj move? I like recording inside Vdj
geposted Wed 12 Feb 14 @ 6:19 am
Yes, it is full MIDI..
Quote :
geposted Wed 12 Feb 14 @ 3:03 pm
Can u record sets on virtual dj whit the efects built in the mixer?
geposted Tue 01 Apr 14 @ 8:08 am
