Hi everybody.....
(1st topic :P)
i have recently downloaded some skins and effects but i cant instal them cause when i double click on the exe it says that the programm does not exist but i run the virtual dj(version if my mk2 console) normally ..... :/ plz help me guys i realy need these.... :P
(1st topic :P)
geposted Wed 05 Jan 11 @ 1:31 pm
i have the same problem when i try to instal skins or effects an error apears (virtual dj not found or software not found)
geposted Thu 06 Jan 11 @ 5:16 pm
Only small amount of plugins are available to LE users I beleive, check plugin for compatibility before downloading.
geposted Thu 06 Jan 11 @ 7:03 pm
DJ Console Edition v3 that comes with the MK2 console does support sound effects and skins, but only those that have been designed for VirtualDJ v3 or earlier.
Any plugins designed for newer versions such as v4, v5, v6 and v7 will not be compatible.
To use newer effects, skins and much, much more you will need to upgrade to the latest VirtualDJ Professional at a discount: http://www.virtualdj.com/buy/index.html
geposted Thu 06 Jan 11 @ 9:04 pm
so to use any plugins and skins i have to find those that have been released berore my controller????
how can find them???
geposted Fri 07 Jan 11 @ 5:04 am
How to install a mapper of a Hercules 4-mx in vdj¿?¿?¿
geposted Fri 07 Jan 11 @ 10:45 am
On the download pages (E.g: http://www.virtualdj.com/addons/effects.html ) you will see which version each plugin has been designed for, e.g: Created for VirtualDJ version 7.x
For your version, only plugins created for version 3.x or 2.x will work.
geposted Fri 07 Jan 11 @ 11:43 am
It is already natively supported in VirtualDJ v7.0.2, so there is no need to install a mapper unless you wish to change or customise the default mapping.
NOTE: You can customise the default mapping to suit your own preferences via CONFIG -> Mappers - Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html for basic instructions.
You can download the latest VirtualDJ Pro from http://www.virtualdj.com/download/updates.html
If you wish to install a custom mapper, copy its mapping file to My Documents\VirtualDJ\Mappers (Or /users/YOURNAME/Documents/VirtualDJ/Mappers if you have a Mac)
If there is also a definition file too, this needs to go in My Documents\VirtualDJ\Devices
geposted Fri 07 Jan 11 @ 11:49 am
thanks a lot guys!!!!!
that was a big help for me!!!! :)
geposted Fri 07 Jan 11 @ 1:21 pm
it is alla working perfectly thanks a lot!!!!
:D :D
:D :D
geposted Fri 07 Jan 11 @ 1:24 pm
