Forum: Old versions
Topic: Mixdeck/Virtual Dj LE - Page: 1
A few days ago I purchased a mixdeck, which came with virtual dj LE in the box. I hooked up the mixdeck and installed VDJ, then configured it. (inputs-none outputs-single output soundcard-simple-numark mixdeck) The mixdeck recognizes the songs on each individual decks display, and i can scratch and control music effects, but both the left and right deck play over channel 1, when I crossfade to channel 2 both songs fade out. Am I missing something? The crossfader in the VDJ program works if I move it by mouse but thats it. Also the headphones have the same problem on the mini fader. Also I run a mac, help would be fantastic thanks
geposted Wed 05 Jan 11 @ 7:52 pm
Hi, I am also having this same problem. I have all the newest drivers and i am using a mac. Does anyone know if there will be a fix for this?
I figured it out. The sound has to be on Soundcard - 4-Out
Soundcard Drop-down - Numark MixDeck for it to work.
I tried the 4 output stage, but now I get sound out of both channel 1 and channel 2 from one deck. Any suggestions?
if you change it in the settings to using a asio driver it will work fine
i have mine running like that it it works well
the only thing that doesnt work in the program is the the crossfader in virtual dj, it doesn't move, but the sound still fades from one deck to another when u use the crossfader on the mixdeck
Thats because its not a MIDI mixer its a hardware mixer, meaning it cant control the program............
Huey
YES I CAN HELP U GUYS WHEN U START VIRTUAL DJ GO TO SETTING & THEN GO TO SOUND CARD OUT PUT EXTERNAL MIXER & SOUND CARD NUMARK MIXDECK THEN GO TO ADVANCE OPCTION CLICK TO TRY 20 DAYS PRO VERSION THEN U HAVE NO PROB WITH CROSSFADER COZ THEY R GIVING DEMO VERSION WITH MIX DECK WE HAVE TO BUY
PRO VERSION THXX
The crossfader of the MixDeck is NOT MIDI CAPABLE and will not move the on-screen crossfader in VirtualDJ regardless of whether you are using VirtualDJ LE or the full Pro or Pro trial. It is unfortunately a hardware design limitation of the MixDeck console.
The same applies to the rest of the mixer section of the MixDeck - It is a real audio DJ mixer and is not MIDI capable. Only the CD player sections are MIDI capable.
VirtualDJ LE is limited but otherwise fully functional software. It is NOT a demo. For an overview of the differences, please see https://virtualdj.com/products/comparison.html
If you wish to upgrade to the full VirtualDJ Pro, we offer a very generous discount to do so: https://virtualdj.com/buy/
NOTE: If you are using VirtualDJ LE v6, then please upgrade to VirtualDJ LE v7 (Free upgrade) to be able to use the External Mixer option in CONFIG -> Sound Setup: https://virtualdj.com/download/updates.html
does any one know hot to change the song with out the music beacause i have a mixdeck that came with virtual dj le and most of the stuff works but when i have music on deck 1 playing i want to play a diffrent song on deck 2 but when i try to place a song on it the music stop on deck one what do i do
Please do not post the same message more than once (Your other duplicate message has been moderated.)
Your sound settings may be set incorrectly.
First, please ensure that you have the latest VirtualDJ LE v7 installed: https://virtualdj.com/download/updates.html
And the latest drivers and firmware from: http://www.numark.com/mixdeck
Then go to CONFIG -> Sound Setup and set your sound as follows:
Inputs: None
Outputs: External Mixer
Sound card: Numark
Click APPLY.
[quote=Support staff]Please do not post the same message more than once (Your other duplicate message has been moderated.)
Inputs: None
Sound card: Numark
Click APPLY.[/quote
Hello. I'm having this kind of problem to. I do the same settings you say but it doesn't do anything i only can hear the music in my computer but not thru the speakers.
Inputs: None
Sound card: Numark
Click APPLY.
well i have tried everything and no sound out of my speakers is there anything else
ok i have downloaded all software and put my sound settings input-none
output-external
soundcard-numark
but the software works but no sound comes out of speakers please help
What do you have the selectors set at on the MixDeck, Deck, CD, AUX? Where do you have the cable to your speakers coming from, master, booth or record? Do you get sound out of your headphones?
Huey
hey huey i have the settings on pc and the volume on master
hey huey i have the settings on pc and the volume on master no sound out of head phones
How do you reset hot que points everytime i put a song on that iv used before it has the same que points how do i rest it any help thanks
VirtualDJ always saves the cue points that you have set with the song so that they are available for when you play the song in future (Typically they will always be set in the same place.)
If you do not want to save them, you will need to delete any cue points that you have set before you load the next song (Or exit VirtualDJ.)
(Right-click on the cue markers in the song overview waveform to delete them.)
I have just down loaded Virtual Dj Pro and songs load up on screen but play out of one channel on the numark mixdeck even when fader is down?????I need help please!!!Thanks Vinyl Girl I just sold my turntables to have this :(
Make sure that you have the latest firmware installed from: http://www.numark.com/mixdeck
Inputs: None
Sound card: Numark (Or 4 out card -> Choose the MixDeck in the drop-down list)
Click APPLY.
Make sure that the channels on the mixer section of the MixDeck are set to PC.
NOTE: If you have set your sound to play out of the speakers of your Mac, then the mixer of the MixDeck will have no effect on this. This is because the MixDeck is a real hardware analogue mixer that is not MIDI capable and cannot control the internal software mixer in VirtualDJ in any way. The MixDeck should always be used with the configuration above and a pair of amplified stereo speakers connected ot the master output on the back.
56%
