Forum: Old versions
Topic: Audio Config Error
A few weeks ago I've run into a new problem with my audio. It happens on 7.0 and still on 7.0.2. When I open VDJ and mount a track it shows it mounting and everything but when I hit play nothing happens. No movement, no sound, music etc. I have discovered that if I try to put another track on the same deck it says a track is already playing, do you really want to replace it.
I use Hercules MK 4 and have the latest driver updates. The only other change is a week before this issue started I upgraded to the latest itunes and there was a minor OSX update as well.
My audio config is:
Inputs: Line Ins ( I have an external MP3/cd player online as a backup)
Outputs: Master Channel 1&2 / Headphones Channel 3&4 (This pertains to the Hercules)
Soundcard : DJConsoleMK4
I have a work a around but I shouldn't have to do this. That is, I change the Input from Line INs to something else, click apply and usually it still doesn't work but then go back to config and change Input back to Line Ins and it works........... about 70% of the time. If it doesn't I close virtual dj down, open it and try the same back and forth combo's till it begins playing and working normal (as it use to)
This is frustrating and scary cuz at gigs I can't afford to NOT have it work.
Help Please, any ideas would be great. Thanks.
PS I just noticed I have 2 virtual dj pro programs on the Mac, 7 which is about 34 mb and the newest 7.0.2 at about 13.2mb. Could this be an issue and/or do or should I have or need both programs on my Mac?
MacBook Pro
MB471LL/A 2.8GHz Intel Core 2 Duo A1286
4gb 1067MHz DDR2 SDRAM
OS X 10.6.5
Nvidia 9400M/9600M GT Graphics
500gb 7200rpm Internal Drive
320gb External Drive (Videos)
VDJ Pro 7.0.2
Hercules DJConsoleMK4
geposted Thu 06 Jan 11 @ 11:18 pm
I'm not sure, but i believe VDJ is waiting for the Input from LineIn when you use this setting.
Give the following a try, maybe it is the tightway for you.
Haui70 wrote :
Never tried this but i believe it works.
Use a 4Deck Skin and then configure the Advanced Config like this:
Master -> Omni SK ASIO -> Output 1&2
Headphone -> Omni SK ASIO -> Output 3&4
Linein1 -> Omni SK ASIO -> Input 1&2
Then connect your iPod with your Omni Soundcard (Input1)
After that create a Keyboard Shortcut with the Action - deck 3 linein 1 on
If you now press play on your iPod "and" press the button on your keyboard, the iPod sound comes out.
But you can only adjust the volume (linefader) inside VDJ, but you can't use VDJ to control the iPod.
To select a track, press play/stop etc. you have to use the iPod himself.
I believe also, the Sync function, did not work.
Replace Omni to MK4 ;-)
Go to System Preferences > Sound, and make sure the MK4 is NOT selected as your main output device.
VDJ doesn't seem to like it when this is the case.
Thanks guys. I will play with this options and report.
I tried the simple fix of just changing my sound preferences, where MK4 was not the output default and it's working so far. I am off to a gig and will continue to see if I don't have to make any back and forth changes. Thanks for the great genius help!!
he guys,
i think theres a problem with my VDJ as well, and i'm struggling for days now..
I work with a Macbook Pro version 10.6.6.
I bought a Numark Omni Controller and CUE ( updated it to 7.0.2 for MAC ).
Sometimes it works, sometimes not.
I only use it with my headphones and a speaker.
How can CUE play smoothly on my Omni Controller ?
Thanks allot !
An attempt to make it Numark NV 2 controller work entire system freezes so it will not play Help.
How do I set back to default so I can continue
NV II does not work with VDJ 7 period
The OP has moved on in 2011 and so will we.
Locked by AMAHM
