Hi all...hope all are well :-)
I have just purchased the Hercules Console after much deliberation and reading all the reviews you people have put on the boards over the last 6 months or so - thanks!
Anyway I was wondering whether HDJC works with the professional edition of VDJ (which i have) and how easy it is to set up. Any guidance would be much appreciated.
Cheers...
Cheers...
geposted Wed 13 Jul 05 @ 8:46 pm
Do this:
1) Plug
2) Play
It definately works with the proffesional version, just install the latest drivers from www.hercules.com
once you have the console, then it's just a case of enableing it in the virtual dJ config window.
Hope you enjoy it ;).
1) Plug
2) Play
geposted Wed 13 Jul 05 @ 9:01 pm
Excellent - thanks :-)
geposted Wed 13 Jul 05 @ 9:09 pm
