Forum: Old versions
Topic: SKINS VIRTUAL DJ 7
I just bought the Virtual DJ, works very nice! BUT, I can't intall the skins virtual dj 7 (4 decks). Always error "error line 314 XML. Can anybody help?
geposted Sat 08 Jan 11 @ 12:53 pm
The software that you have with your VMS4 is VirtualDJ v6. Skins designed for newer versions of the software (VirtualDJ v7) will not work with it. VirtualDJ v6 does not support 4 decks.
NOTE: The software that you received with your VMS4 is a free limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins, effects and much, much more you will need to upgrade to VirtualDJ Professional: https://virtualdj.com/buy/
You can try out Pro features in VirtualDJ v7 Home FREE by going to https://virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
Your VirtualDJ LE entitles you to a discount off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/
