I'd like to see a drop down menu in the browser for tracks with alot of remixes/instrumentals/bonus beats. This way, you would type in the track, only one would appear with the little + sign next to it, you hit the + sign and expands to all of the mixes of that particular track.
Example:
Track 1
remix 1
remix 2
remix 3
instrumental
acapella
bonus beat
This would be a great time saver for some of us since some track names completely fill the browser with remixes.
Thanx Atomix
Example:
Track 1
remix 1
remix 2
remix 3
instrumental
acapella
bonus beat
Thanx Atomix
geposted Sat 08 Jan 11 @ 3:11 pm
You can use the empty field1 and field2 to add those infos, and use them later as Filter FOlder options (criteria) but not as a drop down menu.
geposted Sat 08 Jan 11 @ 7:35 pm
Can the "Feild 1" and "Feild 2" be renamed though? If they can, that would be a good start.
geposted Sun 09 Jan 11 @ 6:44 pm
I think you can change the Labels of those fileds appearing on the columns headers, if you edit the language.xml. You will still have to use Field1, 2 for syntax though.
geposted Mon 10 Jan 11 @ 8:34 am
