for visualizations a slideshow can be activated.
can it be made also for the bitmaps.
Perhaps a map called "Bitmaps" can be foreseen from where the files for the slideshow can be picked up.
or as it is now, specify the location and all bitmaps in that directory will be shown according the time the user has set.
thanks
Johans
thanks
Johans
geposted Thu 14 Jul 05 @ 10:42 pm
Great feature request! Great for sliding mingle pictures from previous club nights for instance.
geposted Thu 14 Jul 05 @ 11:00 pm
It already works like that ;-)
Select a directory for your bitmaps and activate slideshow
geposted Fri 15 Jul 05 @ 1:28 am
Well thanks for the information, seems an undiscovered functionality from my side, I will try it out this evening.
Any idea when there is an update of the manual.
regards
Johans
regards
Johans
geposted Fri 15 Jul 05 @ 1:15 pm
oooh... :)
geposted Fri 15 Jul 05 @ 5:48 pm
Wow, it works fine
many thanks
Johans
many thanks
Johans
geposted Fri 15 Jul 05 @ 6:58 pm
You're welcome
geposted Sat 16 Jul 05 @ 12:00 am
Only works for '.bmp' files though. How about '.gif' '.jpg', etc. ?
geposted Mon 18 Jul 05 @ 6:23 pm
Convert.
geposted Mon 18 Jul 05 @ 6:25 pm
Do you know of a batch converter?
geposted Mon 18 Jul 05 @ 6:29 pm
yes... try this out. Neat tool for mainly converting, but has other interesting features
http://www.reasoft.com/products/reaconverter/
geposted Tue 19 Jul 05 @ 8:54 am
It works for:
.JPG
.BMP
.GIF
.PNG
Take the name bitmap as pictures ;-)
If it doesn't work, write the name of your graphical card as i know ati card limited the size of the picture but it was corrected
.JPG
.BMP
.GIF
.PNG
geposted Tue 19 Jul 05 @ 4:46 pm
