Can anybody help me out here. When I try to record video, I keep getting video codec error. Did a quick serch, and saw that someone said to leave the codec option blank. When I did that, I was able to record but the video as well as the music was jittery and fast as if on crack.
I downloaded k-lite codec, but still have the same problem. Any thoughts, or solutions?
geposted Wed 12 Jan 11 @ 12:06 am
what version of virtualdj are you using,i use microsoft mpg4 in the drop down box using virtualdj 7 and it works for me, also are you using a second monitor while you mix if so make sure its not maximize, i find thats the biggest culprit, just drag the virtualdj window onto the second monitor and leave it the same size.finally figure it out after about 4 hours.
geposted Thu 13 Jan 11 @ 9:09 pm
Using 7, I've tried with a monitor and without. Always same results.
geposted Sun 16 Jan 11 @ 1:07 pm
