I will be using it for video mixing of course! Let me know what you think I should do or add or change.
Rackmount Case - I-STAR D-300 BK Black 3U Rackmount Case ($200)
http://www.newegg.com/Product/Product.asp?Item=N82E16856999301
Motherboard - ASUS P4C800-E Deluxe ($185)
http://www.newegg.com/Product/Product.asp?Item=N82E16813131464
Processor - intel Pentium 4 3.0E ($185)
http://www.newegg.com/Product/Product.asp?Item=N82E16819116171
Ram - CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM ($125)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145450
Sound Card - Delta 44 ($150)
http://www.newegg.com/Product/Product.asp?Item=N82E16829121115
Video Card - ATI 100-435105 Radeon 9800PRO 256MB ($190)
http://www.newegg.com/Product/Product.asp?Item=N82E16814102361
DVD Burner - ($50)
Hardrives - 2 200 Seagates ($250)
Case - 10x6 gator case ($200)
Monitor - NEC 17" ($240)
http://www.newegg.com/Product/Product.asp?Item=N82E16824002278
Monitor rackmount adjuster WHERE CAN I GET ONE??? ($150)
Keyboard Rackmount Drawer ($100)???
So what do you think!? Let me know your opinions!
DVD Burner - ($50)
geposted Fri 15 Jul 05 @ 9:03 am
PCI-Express mobo and graphics? Much faster than "good old" AGP.
geposted Fri 15 Jul 05 @ 9:27 am
How about this?
Video Card - Geforce 6600GT 128MB 128-bit GDDR3 PCI Express x16 Video Card
http://www.newegg.com/Product/Product.asp?Item=N82E16814127147
motherboard - ABIT AA8-3RD EYE Socket T (LGA 775) Intel 925X ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813127192
geposted Fri 15 Jul 05 @ 5:41 pm
Mobo seems fine.
Maybe a 256mb card is more preferred. Compare it with this one. I'll sure go with this one instead. Costs a bit more, but you will probably not regret it though.
http://www.newegg.com/Product/Product.asp?Item=N82E16814127173
However, I am not sure if it is more important to have more RAM on your graphics or if it's as much RAM for the system that is preferred for video mixing in VDJ.
geposted Fri 15 Jul 05 @ 5:56 pm
the speed of the ram and gpu are more important than memory in regurds to video cards. Memory beyond 128 really isn't needed for vdj video, but dosen't hurt either. So the choice is up to you. PCIe is very good, but remember we wern't able to fully use agp to the 8x spec either.
geposted Fri 15 Jul 05 @ 7:14 pm
I recommend The Intel motherboard D945GNTLR ($128)
http://www.newegg.com/Product/Product.asp?Item=N82E16813121290
. And change your memory to DDR2 667 ($173)
http://www.newegg.com/Product/Product.asp?Item=N82E16820144199
Processor 530J: ($175)
http://www.newegg.com/Product/Product.asp?Item=N82E16819116200
You got more performance with this. If you have a little more go for the 630 Intel Processor or the 640.
You could use 4 SATA and put in Matrix RAID 50 (which is supported by this motherboard).
http://www.intel.com/design/motherbd/nt/nt_available.htm
geposted Fri 15 Jul 05 @ 7:43 pm
I think the case you select will not cold all the devices properly. I will go for this:
http://www.newegg.com/Product/Product.asp?Item=N82E16811129151
Or change the power supply with one with 450 watts and a double fan (one face it to the interior of the CPU and the other face it to the outside). The heat will be and issue with the previously case you select.
geposted Fri 15 Jul 05 @ 8:09 pm
http://www.newegg.com/Product/Product.asp?Item=N82E16811129138
What about that case? Will that do with the motherboard you recommended?\
What Nvidea GEforce 6600 card do you use Cyder and where did you get it from? Can you or anyone give me the link to that? There are so many!
geposted Tue 26 Jul 05 @ 8:19 am
check with pcstats.com for the best 6600 card out there and shop for it! OR tomshardware.com
geposted Wed 27 Jul 05 @ 8:48 am
6600GT very important you get the gt version of the card. I like the gigabyte ones myself. I picked mine up from newegg.com. I think it was about 140.
geposted Wed 27 Jul 05 @ 9:57 am
I think I answer you before, but didn't see posted :-s ... Well, Cyder was right the video card for NVidia most be GT for optimal performance. And the case I recomend was for the processor chip you may use. The 2 case is fine too. And take a look for the D955 based motherboard is the best (of intel) http://www.newegg.com/Product/Product.asp?Item=N82E16813121286 ($266)
And you could use a D945P based motherboard 'cause you don't will use an integrated video card (like D945G)
http://www.newegg.com/Product/Product.asp?Item=N82E16813121288 ($124)
Detail Specs: http://www.intel.com/design/motherbd/vs/vs_available.htm
geposted Thu 28 Jul 05 @ 5:06 pm
The last detail specs, was for D945PVS ($166) http://www.newegg.com/Product/Product.asp?Item=N82E16813121287
Detail specs: http://www.intel.com/design/motherbd/vs/vs_available.htm
For D945PNS ($124) http://www.newegg.com/Product/Product.asp?Item=N82E16813121288
Specs: http://www.intel.com/design/motherbd/sn/sn_available.htm
I hope this is useful to you, good luck!
geposted Thu 28 Jul 05 @ 5:31 pm
