Hello, I had recently purchased the new Hercules 4-mx. all the software downloads went smoothly as well as the download for the VDJ LE. Now i am noticing that whenever i use VDJ for about an hour my computer just shuts off. I tried many things to decrease this from happening such as doing a hard drive defrag and downloading a game booster to shut off all un wanted programs while im using the 4-mx, but it still is occuring. My computer is fairly new, I am running Windows 7 64 bit, 4 GB of ram and i have a intel core duo 2 (2.2 ghz). I dont think that this should be happening considering my specifications are well over the recommended specs stated by atomix.If anyone has any knowledge on what i may be doing wrong please help me.
geposted Thu 13 Jan 11 @ 3:47 pm
I'm also having problems with the Hercules 4mx. After fully installing everything when I try to open up VirtualDJ I get this error message
"Invalid skin file (error line 0 in the xml)"
Edit: Resolved my issue. It required that I was signed in as Administrator.
geposted Thu 13 Jan 11 @ 5:04 pm
axfrankieax wrote :
... for about an hour my computer just shuts off.
It seems you have a temperature issue. Download a Temp Monitor Tool, and notice the behaviour
geposted Thu 13 Jan 11 @ 5:29 pm
This is probably because you are trying to use a skin made for ver7 and you run an earlier version.
Download the FREE Home ver 7 https://virtualdj.com/download/free.html
geposted Thu 13 Jan 11 @ 5:32 pm
okay i will try that. Thank you very much!
geposted Thu 13 Jan 11 @ 6:23 pm
