hi folks i use a usb sound card with my laptop is there a way i can listen to both tracks at same time using headfones and another question i subscribe to premium membership but i cant record any muic from the genius dj everytime im mixing i usealy record and i go to place in a song from netsearch and it stops recording its reely frustrating :(
geposted Fri 14 Jan 11 @ 6:14 am
Any music you get from netsearch is DRM protected, you can only playback not record. As for listening to both tracks it is possible since you have 2 soundcards. Pick 1 soundcard for your master out and the other for your headphones.
Hope that helps
Huey
Hope that helps
Huey
geposted Fri 14 Jan 11 @ 6:29 am
To prelisten both decks with your current sound setup, simply select both PFL buttons in the default skin.
geposted Fri 14 Jan 11 @ 8:37 am
ye i push the PFL butttons but it switches sides so i cant listen to both songs in the headfones, is there a way to select them both or a way to listen to both sides at one time ...
geposted Fri 14 Jan 11 @ 9:45 am
Since the default 2 deck skin has PFL assigned as deck select, you may use some keyboard shortcuts to control the PFL
deck 1 pfl
deck 2 pfl
If you know how to edit the xml file of a skin then you can change the ..
action="deck 1 select"
to
action="deck 1 pfl"
and same thing for deck 2.
You can also use the default 4 deck skin which has PFL buttons on the mixer panel.
deck 1 pfl
deck 2 pfl
to
action="deck 1 pfl"
geposted Fri 14 Jan 11 @ 9:10 pm
If you are using a default VDJ skin, look along the top row of controls (near the config button) and you will see the headphone volume and next to that the headphone mix. Turning the headphone mix clockwise will allow you to hear the master output as well as any PFL outputs, turning anticlockwise will allow you to hear the PFL outputs only.
Hope that helps
Simon
Hope that helps
Simon
geposted Sat 15 Jan 11 @ 9:13 am
thanks alot folks that reely helped !
geposted Sat 15 Jan 11 @ 12:26 pm
And Is there a way you can deselect pfl on both channels
I want to use a 3 channel soundcard (external mixing deck)
1+2 = left deck
3+4 = Right deck
5+6 = peview player only (without left or right deck)
1+2 = left deck
3+4 = Right deck
geposted Sat 15 Jan 11 @ 4:57 pm
Doubleposting your issues, will not help you to get answers..
https://virtualdj.com/forums/141307/General_Discussion/deselect_pfl_on_both_decks.html
geposted Sat 15 Jan 11 @ 7:35 pm
