Ecco il nuovo controller Gemini Ctrl-47, a 4 decks con scheda audio integrata.
Gemini wrote the book on DJing back in 1974, but now we’re rewriting it.
“Digital DJ” was once a bad-word amongst DJs, embodying the loss of control and feel over their DJing trade. But the Gemini CTRL-47 was designed for DJs by the company who knows them better than anyone.
When Gemini set out to make the ultimate hardware controller, the idea was to make a simple, yet powerful and fluid professional Digital DJ system.
The CTRL-47 gives you a premium-quality 4-channel DJ mixer, an intuitive DJ controller with familiar feel and two touch-sensitive jogwheels as well as a built-in 24 bit/192 kHz soundcard with stable, latency-free ASIO drivers. It gives you maximum control over your DJ software with controls for loops, effects, tone controls, samples, hot cues, and pitch while included VIRTUAL DJ 7 software gets you straight to mixing (The CTRL-47 also works with other popular DJ software)
The CTRL-47 is the ideal solution for mobile DJs as it provides everything you need to rock a party in one highly portable unit. The included inputs and outputs of the soundcard make it easy to hook up other gear - including a microphone while its streamlined and compact profile makes it a pleasure to transport from gig to gig.
* The CTRL-47 provides pristine audio quality with its built-in 24-bit/192 kHz soundcard with stable, latency-free ASIO drivers.
* The 4-channel mixer has smooth 60mm faders along with gain control and a 3-band EQ on each channel.
* Two touch-sensitive jogwheels allow you to scratch and cue your music while the ergonomic layout provides intuitive controls for loops, effects, samples, hot cues, and pitch adjustment.
* The flexible inputs/outputs of the CTRL-47 accomodate nearly any setup with a switchable line/phono RCA input and XLR and ¼” mic inputs. The output section includes balanced XLR outputs, Master, Booth, and Record stereo RCA outputs, S/PDIF digital audio output, and ¼” & 1/8” headphone inputs for its cueing section.
* Included VIRTUAL DJ 7 software gets you straight to mixing with your digital library. The CTRL-47 can also be MIDI-mapped for use with other popular DJ/music production software.
http://www.geminidj.com/products/items/265
geposted Sat 15 Jan 11 @ 5:37 am
mi sembra come plasticoso....troppo plasticoso...una mia impressione??
geposted Sat 15 Jan 11 @ 7:17 am
a me non sembra proprio.
Un prodotto molto molto interessante da valutare meglio quando si sapra' il prezzo. Con il Namm 2011 il valore tecnico medio sembra essersi alzato notevolmente e anche Gemini produce quello che all'apparenza è un ALL IN ONE quanto meno semi-pro.
Per ora mi piace parecchio...
geposted Sat 15 Jan 11 @ 7:27 am
mi sbaglierò io...sarà che mi appare così a prima vista...
geposted Sat 15 Jan 11 @ 7:37 am
