in virtual dj under the settings tab.
what is everyones settings, for best recommended
sound, and working of vdj.
e.g
auto bpm: enabled/disabled
auto gain: enabled/disable
auto pitch reset: enabled/disabled
beatlock: ridgid/elastic
limiter: enabled/disabled
time stretch: enabled/disabled
which settings make for best sound/usage of vdj?
e.g
geposted Sun 24 Aug 03 @ 10:17 am
I disable time strech (electronic music). In my opinion, the engine works a little better fine than if time strech is disabled.
geposted Sun 24 Aug 03 @ 2:42 pm
really? I will have to try that. at least it sounds better than other DJ programs. BPM studio sounds all warbled when you slow it down beyond 8% master tempo! Virtual DJ could use some improvement
geposted Sun 24 Aug 03 @ 4:35 pm
